Preferences not working with ESP32-S2 and PlatformIO, BUT working with Arduino IDE
I cannot use the built in preferences library when using PIO, ESP32-S2 and the Arduino framework.
When using the normal Arduino IDE, the code works!
My platformio.ini:
[env:esp32-s2-saola-1]
platform = https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
board = esp32-s2-saola-1
monitor_speed = 921600
main.cpp:
#include <Preferences.h>
Preferences preferences;
  Serial.begin(921600);
  Serial.println();
  // Open Preferences with my-app namespace. Each application module, library, etc
  // has to use a namespace name to prevent key name collisions. We will open storage in
  // RW-mode (second parameter has to be false).
  // Note: Namespace name is limited to 15 chars.
  preferences.begin("my-app", false);
  // Remove all preferences under the opened namespace
  //preferences.clear();
  // Or remove the counter key only
  //preferences.remove("counter");
  // Get the counter value, if the key does not exist, return a default value of 0
  // Note: Key name is limited to 15 chars.
  unsigned int counter = preferences.getUInt("counter", 0);
  // Increase counter by 1
  counter++;
  // Print the counter to Serial Monitor
  Serial.printf("Current counter value: %u\n", counter);
  // Store the counter to the Preferences
  preferences.putUInt("counter", counter);
  // Close the Preferences
  preferences.end();
  // Wait 10 seconds
  Serial.println("Restarting in 10 seconds...");
  delay(10000);
  // Restart ESP
  ESP.restart();
main.ino (using the Arduino IDE):
 ESP32 startup counter example with Preferences library.
 This simple example demonstrates using the Preferences library to store how many times
 the ESP32 module has booted. The Preferences library is a wrapper around the Non-volatile
 storage on ESP32 processor.
 created for arduino-esp32 09 Feb 2017
 by Martin Sloup (Arcao)
#include <WiFi.h>
  Serial.println();
  counter++;
  preferences.end();
  // Wait 10 seconds
  delay(10000);
  // Restart ESP
  ESP.restart();
void loop() {}
When compiling using the Arduino IDE the code works as expected. When using PIO, the default value is returned, no matter what. I am using the latest version of arduino-esp32 from the master branch.
The serial speed does not influence the results.
Use Support for the latest Arduino v2.0 · Issue #619 · platformio/platform-espressif32 · GitHub
