I have platformio installed running on a Rasbian Jessie Raspberry Pi v3 using the CLI.
I am following the instructions at:
Redirecting...
Sitting in the directory of the application (e.g. /opt/piotest), this works fine:
pio run -t upload
Added an additional line to the existing platformio.ini:
[env:feather32u4]
board = feather32u4
extra_script = pre:/opt/piotest/pre.py
(also tried the extra_script value w/o pathing)
Created a simple python script that just prints a line (and works fine from command line) named pre.py:
print(“starting…”)
Getting this warning:
warning: Ignoring missing SConscript ‘pre:pre.py’
File “/usr/local/lib/python2.7/dist-packages/platformio/builder/main.py”, line 164, in
Nothing additional prints in output.
Checked file permissions and reset everything in /opt to my user, just in case something weird were causing the main.py app to fail. No change.
Removed my original addition to platformio.ini. Copied/pasted your example into platformio.ini and extra_script.py from this thread:
Run script before/after image upload? - #3 by ivankravets
Similar error.
Any ideas on next steps?
Thanks, but yes I tried that prior (and just did again to be certain):
You’re up-to-date!
PlatformIO 3.4.0 is currently the newest version available.
Ah… I got it, pre:post prefixes were added in PlatformIO 3.4.1 which has not been released yet. See history:
You can switch to PlatformIO 3.4.1 dev version Redirecting...
Otherwise, please use documentation for PlatformIO 3.4.0 (stable)
Staying on current version for this test and following instructions linked at:
Running command:
pio run -t upload
Different error after successful upload:
[Fri Jul 14 14:55:58 2017] Processing pre_and_post_hooks (extra_script: extra_script.py)
Error: Please specify platform for ‘pre_and_post_hooks’ environment
Seems like I’m missing a platform setting like:
platform = linux_arm
Just trying to figure out now where to put it in platformio.ini
You are going to process pre_and_post_hooks environment which is empty… Please specify here platform…
[env:pre_and_post_hooks]
extra_script extra_script.py
Edited platformio.ini section to be:
extra_script = extra_script.py
But had to alter first line of sample code for extra_script.py as it is invalid in Python 2.7.9:
Import(“env”)
Changed to a couple of variations:
import env
import PLATFORMIO.env
But still errors out as unknown module.
ImportError: No module named PLATFORMIO.env:
Feels like I’m close now.
Ran a pip freeze to get module names.
Did not work with trying the following as first line in extra_script.py:
from platformio import env
How did you decide that this code is invalid?
Just trying it from the CLI it gives:
File “extra_script.py”, line 1, in
Import(“env”)
NameError: name ‘Import’ is not defined
Is env a part of the platformio package or something else?
This is a PlatformIO script and is not Python’s standalone. You should run it via pio run command.
Tried both. Same error regardless. <- not correct - see next post
Just trying the Python CLI to narrow it down to the syntax first of where the env module is coming from.
(Don’t you hate it when people jump ahead and think they know what you’re going to ask for next and you have to tell them to just stop jumping around and follow your guidance?)
Sorry, maybe I missed that and that line “works” when used within your framework but here’s what I get after putting that line back “as is” w/o modification:
[Fri Jul 14 16:00:12 2017] Processing pre_and_post_hooks (extra_script: extra_script.py; platform: linux_arm)
Collected 3 compatible libraries
Looking for dependencies…
Project does not have dependencies
Current build targets [‘upload’]
***** Do not know how to make File target `upload’ (/opt/platformio/upload). Stop.**
========================== [ERROR] Took 1.79 seconds ==========================
The board I am loading is in deep sleep mode w/ the USB disabled. Therefore, I have to time pressing the reset button on the board to coincide with platformio loading the board. I’d like to play an audio prompt (e.g. tone) right before the code starts loading to the board so that the timing is more accurate and less likely to be missed.
Pre is mostly what I am trying to get a handle on.
Do you understand what does it mean? You are going to build source code using native ARM compiler. Nevertheless, you said that you have a board connected to RPi. If you want to program it you SHOULD use environment which correspond to it. PlatformIO will autoamtically use own dependent toolchins to preapre firmware for your board.
platform = REAL_PLATFORM_HERE
framework = REAL_FRAMEWORK_HERE
board = REAL_BOARD_ID_HERE
Sorry, the configuration is:
- Raspberry Pi 3 v2 (Raspbian Jessie - Minimal)
- Adafruit Feather 32u4 (deep sleep)
Goal is to load updated software to the Adafruit Feather 32u4 from the RPi.
I am assuming that the platform value should linux_arm for the Pi vs. something else for the Adafruit Feather 32u4. Is that incorrect? Perhaps:
platform=Atmel AVR
See PlatformIO Registry
board = feather32u4
