I’m wondering if I’ve found a bug or simply some interaction that I haven’t been able to find documentation for. The summary is that if I change the order of -I PATH
directives in platformio.ini
, the PATH
s themselves will change in the generated g++
command.
For instance, in the following environment I specify -I include/robot_config/default/ -I include/robot_config/${env.ROBOT_NAME}/
[env:main]
platform=atmelsam
framework=arduino
board=samdSerial
src_filter = +<i2c/*> +<main.cpp> +<user_interface/*>
build_flags = -DSERIAL_BUFFER_SIZE=2000 -I include/robot_config/default/
-I include/robot_config/${env.ROBOT_NAME}/ -I include/
-DBLIND_SCAN_I2C=1 -DWATCHDOG=1
upload_port = /dev/ttyS0
lib_deps = 883
A pio run -e main -v
shows the modified paths that causes compilation to fail because it can’t find the correct file on the search path:
-Iplatformio/platforms/atmelsam/builder/include/robot_config/default/, -Iinclude/robot_config
But I can change the include order in platformio.ini
[env:main]
platform=atmelsam
framework=arduino
board=samdSerial
build_flags = -DSERIAL_BUFFER_SIZE=2000 -I include/robot_config/${env.ROBOT_NAME}/
lib_deps = 883
The code compiles successfully with the following -I
directives in the generated g++
command:
-Iplatformio/platforms/atmelsam/builder/include/robot_config/, -Iinclude/robot_config/default
It looks at first like platformio/platforms/atmelsam/builder
is added to the first -I
directive from platformio.ini
, but the odd thing is that adding another -I
directive (say, -I include/robot_config/foo/
) to the main
environment in platformio.ini
results in the following g++
-I
directives:
-Iplatformio/platforms/atmelsam/builder/include/robot_config/foo, -Iplatformio/platforms/atmelsam/builder/include/robot_config/, -Iinclude/robot_config/default
So, what’s going on here? Why does a path get appended to my -I
directives, and only (seemingly) for the last file?
