In platformio.ini in [env]
I have declared extra_scripts = post:scripts/postprocessor.py
. This in itself appears to work, however when I try to use env.AddPostAction('build', callback)
after Import('env')
, the callback which should just run a print statement appears to do nothing when the ‘Build All’ task is run from the default project tasks.
Full platformio.ini here.
Regards.
