Hello.
I want to use Atmel Studio code on PlatformIO(as native and NOT arduino). This code compiles successfully on Atmel Studio and include asm code inside C code. When I port this code on PlatformIO, the compiler marks all register names r0…r#(inside asm) as errors “unknown register name ‘r0’”
As I understand, such error already has been on this ticket and later developers fixed the problem:
opened 07:55PM - 20 Nov 18 UTC
closed 01:02PM - 21 Nov 18 UTC
enhancement
With a default project on the AVR platform (e.g. `megaatmega2560`), calls to som… e common AVR macros (e.g. `pgm_read_word`) produce spurious errors in the automatic on-save Intellisense, i.e. "unknown register name 'r0'". This is caused by the vscode-cpptools extension calling avr-gcc without the correct command line arguments to specify the AVR MCU in use. See [this not-bug on their issue tracker](https://github.com/Microsoft/vscode-cpptools/issues/2377).
The PlatformIO-generated c_cpp_properties.json needs to be modified to include the correct `-mmcu` option in ""compilerPath". (Which is badly named; per the vscode-cpptools docs, that's where compiler flags should go.) This is board-dependent. For me (board = megaatmega2560), adding "-mmcu=atmega2560" eliminates the errors—until PlatformIO next overwrites the file.
(There are some other issues with vscode-cpptools intellisense; for example, it doesn't show any warnings on save, although it usually will pick up warnings from a PlatformIO build. Not sure why that is; adding `-Wall` to "compilerPath" does *not* fix that.)
But now this error appeared on my way with PlatformIO (latest and updated).
You can see my details in new ticket:
opened 12:57PM - 27 Mar 20 UTC
closed 07:05PM - 31 Mar 20 UTC
Like this closed issue:
https://github.com/platformio/platformio-vscode-ide/iss… ues/421
I have this errors on latest PlatformIO:
pio update
Updating contrib-piohome @ 3.1.1 [Up-to-date]
Updating contrib-pysite @ 2.37.191017 [Up-to-date]
Updating tool-unity @ 1.20500.200322 [Up-to-date]
Updating tool-scons @ 3.30102.0 [Up-to-date]
Platform Manager
Platform Atmel AVR
Updating atmelavr @ 2.0.0 [Up-to-date]
Updating toolchain-atmelavr @ 1.50400.190710 [Up-to-date]
Platform Espressif 8266
Updating espressif8266 @ 2.4.0 [Up-to-date]
Updating toolchain-xtensa @ 2.40802.191122 [Up-to-date]
Updating tool-esptool @ 1.413.0 [Up-to-date]
Updating tool-esptoolpy @ 1.20800.0 [Up-to-date]
platformio.ini
[env:attiny13a]
board = attiny13a
board_build.mcu = attiny13a
board_build.f_cpu = 1200000L
upload_protocol = usbasp
upload_flags = -Pusb
Editing **c_cpp_properties.json** does nothing more so already there is an option
> "compilerArgs": [
> "-mmcu=attiny13a",
Please help me deal with the problem…
Does your project compile when using pio run
(aka the “Build” button) or does the VSCode Intellisense just complain about a “problem”? If it’s a compile error, can you post the complete compile error?
Log "pio run -v"
C:\Users\Dima\Documents\PlatformIO\Projects\HumidityAttiny25>pio run -v
Processing attiny25 (platform: atmelavr; board: attiny25; board_build.f_cpu: 1000000L; upload_protocol: usbasp; upload_flags: -Pusb)
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/attiny25.html
PLATFORM: Atmel AVR 2.0.0 > Generic ATtiny25
HARDWARE: ATTINY25 1MHz, 128B RAM, 2KB Flash
Found 0 compatible libraries
avr-gcc -o .pio\build\attiny25\src\main.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny25 -DF_CPU=1000000L -DPLATFORMIO=40301 -DARDUINO_AVR_ATTINYX5 -Iinclude -Isrc src\main.c
avr-gcc -o .pio\build\attiny25\src\softuart.o -c -std=gnu11 -fno-fat-lto-objects -Os -Wall -ffunction-sections -fdata-sections -flto -mmcu=attiny25 -DF_CPU=1000000L -DPLATFORMIO=40301 -DARDUINO_AVR_ATTINYX5 -Iinclude -Isrc src\softuart.c
In file included from src\softuart.c:50:0:
src\softuart.h:53:0: warning: "F_CPU" redefined
#define F_CPU 8000000UL
<command-line>:0:0: note: this is the location of the previous definition
In file included from src\main.c:15:0:
src\main.c: In function 'main':
src\main.c:29:16: warning: pointer targets in passing argument 1 of 'softuart_send' differ in signedness [-Wpointer-sign]
softuart_send("Hello.\n");
src\softuart.h:70:6: note: expected 'const uint8_t * {aka const unsigned char *}' but argument is of type 'char *'
void softuart_send(const uint8_t *s);
src\main.c:32:20: warning: passing argument 1 of 'eeprom_write_byte' makes pointer from integer without a cast [-Wint-conversion]
eeprom_write_byte(0x127, 0xBB);
In file included from src\main.c:13:0:
c:\users\dima\.platformio\packages\toolchain-atmelavr\avr\include\avr\eeprom.h:166:6: note: expected 'uint8_t * {aka unsigned char *}' but argument is of type 'int'
void eeprom_write_byte (uint8_t *__p, uint8_t __value);
avr-gcc -o .pio\build\attiny25\firmware.elf -Os -mmcu=attiny25 -Wl,--gc-sections -flto -fuse-linker-plugin .pio\build\attiny25\src\main.o .pio\build\attiny25\src\softuart.o -L.pio\build\attiny25 -Wl,--start-group -lm -Wl,--end-group
C:\Users\Dima\AppData\Local\Temp\cc2brKbE.s: Assembler messages:
C:\Users\Dima\AppData\Local\Temp\cc2brKbE.s:114: Error: register number above 15 required
lto-wrapper.exe: fatal error: avr-gcc returned 1 exit status
compilation terminated.
c:/users/dima/.platformio/packages/toolchain-atmelavr/bin/../lib/gcc/avr/5.4.0/../../../../avr/bin/ld.exe: error: lto-wrapper failed
*** [.pio\build\attiny25\firmware.elf] Error 1
======================================================================================== [FAILED] Took 3.07 seconds ========================================================================================
Also I have installed plugin for Sublime Text (Deviot) - and I have the same kind error.
Used this softuart library with asm code:
Links
tinnymodbus/softuart.c at master · cbalint13/tinnymodbus · GitHub
tinnymodbus/softuart.h at master · cbalint13/tinnymodbus · GitHub
On Atmel Studio it compiled properly…
So you put
in the platformio.ini
but put an extra macro there to redefine to 8MHz? This line doesn’t appear in the original library at line 53.
I cannot reproduce this issue.
platformio.ini
[env:attiny25]
board = attiny25
board_build.f_cpu = 1000000L
src\main.c
#include <softuart.h>
int main() {
softuart_send((const uint8_t*)"Test");
return 0;
and softuart.c
, softuart.h
from the links you posted, I get.
>pio run -v
Processing attiny25 (platform: atmelavr; board: attiny25; monitor_speed: 115200; board_build.f_cpu: 1000000L; upload_protocol: usbasp; upload_flags: -Pusb)
Framework incompatible library C:\Users\Maxi\.platformio\lib\MCCI LoRaWAN LMIC library_ID5774
More details about "Library Compatibility Mode": https://docs.platformio.org/page/librarymanager/ldf.html#ldf-compat-mode
avr-objcopy -O ihex -R .eeprom .pio\build\attiny25\firmware.elf .pio\build\attiny25\firmware.hex
MethodWrapper(["checkprogsize"], [".pio\build\attiny25\firmware.elf"])
RAM: [ ] 4.7% (used 6 bytes from 128 bytes)
Flash: [= ] 7.1% (used 146 bytes from 2048 bytes)
.pio\build\attiny25\firmware.elf :
section size addr
.text 140 0
.data 6 8388704
.comment 48 0
.note.gnu.avr.deviceinfo 60 0
.debug_info 1056 0
.debug_abbrev 1000 0
.debug_line 26 0
.debug_str 362 0
Total 2698
============================= [SUCCESS] Took 1.26 seconds =============================
Can you upload your whole project so that it becomes reproducable?
Thanks for your answer.
I solved my problem, it turned out that the variable with the name “buf” is some kind of system element and has a different sence.
This resulted in a compilation error.
I renamed the variable “buf”=>“buff”, and now compilation is successful.
However, the syntax with highlighting “unknown register name ‘r0’ ” still showing and I think it led to the false path of my throwing.
This is still a valid VSCode Intellisense bug though it seems (AVR Assembler Errors (i.e. Arduino) · Issue #2377 · microsoft/vscode-cpptools · GitHub ). The path to the compiler and the -mmcu
argument is there, but is still somehow won’t pick it up.
