Hello everyone
I am currently setting up my dev environment to program both cores of the Arduino Portenta H7. Compilation for the M7 core works fine.
But if I want to compile the code for the M4 core, I get the following error:
.pio\build\portenta_h7_m4\src\main.cpp.o: In function `BreakoutCarrierClass::BreakoutCarrierClass()':
main.cpp:(.text._ZN20BreakoutCarrierClassC2Ev[_ZN20BreakoutCarrierClassC5Ev]+0x14e): undefined reference to `EMAC::get_default_instance()'
.pio\build\portenta_h7_m4\lib9df\libEthernet.a(Ethernet.cpp.o): In function `_GLOBAL__sub_I__ZN7arduino13EthernetClass5beginEPhmm':
Ethernet.cpp:(.text.startup._GLOBAL__sub_I__ZN7arduino13EthernetClass5beginEPhmm+0x14): undefined reference to `EMAC::get_default_instance()'
*** [.pio\build\portenta_h7_m4\firmware.elf] Error 1
I think the error occurs because the M4 core doesn’t have any Ethernet stuff but I can’t figure out how I can turn of this functionality so it doesn’t get compiled.
My env for the M4 core is:
[env:portenta_h7_m4]
platform = ststm32
board = portenta_h7_m4
arduino-libraries/Arduino_PortentaBreakout@^1.0.1
build_flags=
-I"C:\Users\user\.platformio\packages\framework-arduino-mbed\libraries\Portenta_Audio\src" ; pdm2pcm is not found therefore manually link it here
Can anyone help me?
