Hi All
As of a few hours ago my STM32H7 (Arduino Portenta H7) has stopped loading. When i upload using ST-Link it keeps halting on line 37 of arduino>Main.cpp
initVariant();
if i pull out USB on COM4 (Monitor Port) i can some times get my code to move into my main.cpp but this is hit and miss. If i do some times the Portenta H7 fails with LED blinking red 4 times. Which i belive is a USB fault.
BTW at time of this all starting i was working on GPIO interupts and call back routines, but i cant see what went wrong.
So i went back to run a basics and decided to run a basic blinking code as a test. And it wont work either.
Please help or explain what is going wrong, i fear my device has permantly failed.
Here is the basic code. (NOTE i have updated this to add serial.print()"
// My Baseline
#include <Arduino_PortentaBreakout.h>
// Declare constants and vars
const int ledRed = LEDR; // Pin to use for the LED
const int ledBlue = LEDB; // Pin to use for the LED
const int ledGreen = LEDG; // Pin to use for the LED
// Set LED pin to output mode
pinMode(ledRed, OUTPUT);
digitalWrite(ledRed, HIGH);
pinMode(ledBlue, OUTPUT);
digitalWrite(ledBlue, LOW);
pinMode(ledGreen, OUTPUT);
digitalWrite(ledGreen, HIGH); // Off
//Serial1.begin(115200);
Serial.print("Milli Seconds: " + String(millis()));
delay(500);
digitalWrite(ledBlue, HIGH);
delay(500);
delay(500);
delay(500);
digitalWrite(ledRed, LOW);
delay(500);
delay(500);
delay(500);
delay(500);
digitalWrite(ledGreen, LOW);
delay(500);
delay(500);
delay(500);
delay(500);
platformio.ini
[env:portenta_h7_m7]
platform = ststm32
board = portenta_h7_m7
debug_tool = stlink
upload_protocol = stlink
monitor_port = COM4
https://github.com/maxgerhardt/Arduino_PortentaBreakout/archive/refs/heads/main.zip
-I include
-D TARGET_PORTENTA_H7_M7
here is the terminal
* Executing task: C:\Users\bucko\.platformio\penv\Scripts\platformio.exe run --target upload
Processing portenta_h7_m7 (platform: ststm32; board: portenta_h7_m7; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/portenta_h7_m7.html
PLATFORM: ST STM32 (15.6.0) > Arduino Portenta H7 (M7 core)
HARDWARE: STM32H747XIH6 480MHz, 511.35KB RAM, 768KB Flash
DEBUG: Current (stlink) External (cmsis-dap, jlink, stlink)
- framework-arduino-mbed @ 4.0.2
- tool-dfuutil @ 1.11.0
- tool-openocd @ 2.1100.211028 (11.0)
- tool-stm32duino @ 1.0.2
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
Found 45 compatible libraries
|-- Arduino_PortentaBreakout @ 1.0.1
Checking size .pio\build\portenta_h7_m7\firmware.elf
RAM: [= ] 13.5% (used 70800 bytes from 523624 bytes)
Flash: [=== ] 26.1% (used 205504 bytes from 786432 bytes)
AVAILABLE: cmsis-dap, dfu, jlink, mbed, stlink
Uploading .pio\build\portenta_h7_m7\firmware.bin
xPack OpenOCD x86_64 Open On-Chip Debugger 0.11.0+dev (2021-10-16-21:19)
Licensed under GNU GPL v2
For bug reports, read
debug_level: 1
hla_swd
xPSR: 0x01000000 pc: 0x08000480 msp: 0x24080000
** Programming Started **
Warn : Adding extra erase range, 0x08072620 .. 0x0807ffff
** Programming Finished **
** Verify Started **
** Verified OK **
** Resetting Target **
shutdown command invoked
==================================================================================================== [SUCCESS] Took 5.53 seconds ====================================================================================================
UPDate:
I have tried removing STLINK and programming via USB straight to STM32 (first double press into bootloader). It appears to upload with no errors but after loading there is no sign of life, nothing is flashing.
Going back to Arduino IDE with the above code it complies and runs. Good news my STM32 isnt bricked. Bad news is my problems are with PIO some where. So what is it? i have changed anything that i know of today.
Update: 17/4; 10am
Apon loading to the taget my code fails in
framework-arduino-mbed>variants>PORTENTA_H7_M7>variant.cpp
. the code fails in the this section and it appears that the millis()
and micros()
are not functioning as they are always = 0. Thus stuck in loop. If i comment out i can get past this point some times but it then fails when intialising USB. I assume its a timer in there as well.
BUT if i run the above code in Ardunio IDE it will work and print out the Serial.print("Milli Seconds: " + String(millis()));
thus my STM32H7 is working fine. So my libaries are screwed somehow.
Here is the intial failure point
Update: 17/4 2:20pm
just in case anyone cares, I found an error in variant.cpp. I must have accidentally commented out a line. Stupid Stupid Stupid.
But my onboard USB still does not work when I am using the STLINK V3 in debug mode. But it will work when I upload (via STLINK) . i have my STLINK on COM3 via the arduino breakout board. And I monitor on COM4 from the STM32H7 onboard USB-C. In platfomio.ini i have set the monitor port. monitor_port = COM4
In device manager i can see COM3 and COM4, then i debug and COM4 disappears. Then when i stop debugging COM4 straight away reappears.
So now its a STLINK debug config issue I think.
