Hello all,
This is my first post to the community, but I wanted to post this in case it helps someone else because this one took a while to isolate. Some of this post has been generated with a LLM to save me time typing, but I’ve personally proofread everything and the solution is accurate.
I’m using an Arduino Portenta H7 (M7 core) and building with PlatformIO on a Raspberry Pi Compute Module 5 running Ubuntu 24.04.
Symptom
The firmware would:
build successfully
link successfully
upload successfully
verify successfully
but after reset, the Portenta would not come back as a USB device, and the Serial monitor path never appeared / never worked.
So from the outside it looked like:
upload completed fine
then the board disappeared
no USB CDC device
no serial output
no return to runtime
At first this looked like a bootloader handoff problem, crash after boot, bad flash offset, bad uploader, etc.
What I verified first
I narrowed it down pretty hard before finding the actual fix:
The board itself was fine.
The Portenta bootloader / flash layout were fine.
Uploading from the Pi with OpenOCD over SWD worked.
Uploading via DFU also worked.
A simple sketch built in the Arduino IDE ran correctly.
The Arduino IDE-built ELF also ran correctly when I uploaded that exact ELF from the Pi using OpenOCD or DFU.
That told me the issue was not:
the board
the bootloader
the Pi host
SWD/OpenOCD
DFU
USB wiring
or flash placement
It was specifically the PlatformIO-built firmware artifact.
Important detail
I eventually got the PlatformIO environment lined up so it matched the working Arduino core generation as closely as possible:
platform = ststm32@19.4.0 -
framework-arduino-mbed = 4.4.1
That matters because PlatformIO’s STM32 platform release notes show that ststm32@19.4.0 is the release that updated Arduino-mbed to 4.4.1, while 19.5.0 moved to 4.5.0. [github.com]
Even with that matched framework version, the PlatformIO-built image still uploaded successfully but did not run.
Actual root cause
The problem turned out to be a floating-point ABI mismatch in the PlatformIO build flags.
In the verbose PlatformIO build output, I found that the compile/link command line effectively included both:
-mfloat-abi=softfp
and later
-mfloat-abi=soft
So the build was effectively ending up with the wrong float ABI.
That matters because ArduinoCore-mbed packages much of the Mbed runtime as a precompiled libmbed.a, so if your sketch objects are built with the wrong ABI relative to the precompiled runtime, the firmware can still compile, link, and upload, but then fail very early at runtime.
That is exactly what I was seeing:
upload looked successful
but the Portenta never re-enumerated as USB
serial monitor never came back
board looked “dead” after upload
The fix
The fix was simply to remove the soft ABI flag and force softfp.
This was added to the platformio.ini that made the firmware start working normally:
build_unflags =
-mfloat-abi=soft
-Wall
-g
-mfloat-abi=softfp
After adding that, the exact same PlatformIO project started behaving correctly:
upload succeeds
board resets
Portenta comes back as USB device
Serial monitor works
firmware runs normally
Minimal working config
This is the relevant part of the working config on my side:
[env:portenta_h7_m7]
board = portenta_h7_m7
build_unflags =
-mfloat-abi=soft
-Wall
-g
-mfloat-abi=softfp
I’m also using a custom OpenOCD upload command from the Pi side, but the uploader was not the problem — I had already proven that by successfully uploading and running the Arduino IDE-built ELF through the same OpenOCD path.
Why I’m posting this
This issue was confusing because it did not show up as:
a compile failure
a link failure
an upload failure
Instead, it materialized as:
PlatformIO reports successful upload, but the Portenta never comes back as a USB device and the serial monitor does not work.
So if anyone else sees that exact behavior on a Portenta H7 M7 build, I would strongly suggest checking the final compile/link flags for -mfloat-abi and making sure softfp is what actually wins.
