How do enable flash split like the way that i can do in the arduino ide?
I want too use a 100/0 split meaning that i want all flash to be allocated towards the m7 core and the m4 only uses the sdram.
Because i can’t get the example “BootM4_from_SDRAM” from arduino working using platformio.
is there an option too enable this type of flash split?
i have done this but it still reports the following,
RAM: [== ] 16.7% (used 87432 bytes from 523624 bytes)
Flash: [===== ] 52.1% (used 409888 bytes from 786432 bytes)
Or does this indicator not update with the change too flash_layout
I think it’s an oversight that upload.maximum_size and upload.maximum_ram_size are not updated with the flash layout split, thus the indicated numbers will be wrong, but the firmware will still be built, linked and uploaded correctly.
