Please ignore this one- Class has no such member
“BLE Advertising” is on line 42. Then we start ‘void setBeacon()’, and the error is raised several lines later. I can’t see how they’re connected.
   Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleScan.cpp
   Ported to Arduino ESP32 by pcbreflux
   Create a BLE server that will send periodic iBeacon frames.
   The design of creating the BLE server is:
   1. Create a BLE Server
   2. Create advertising data
   3. Start advertising.
   4. wait
   5. Stop advertising.
   6. deep sleep
#include "sys/time.h"
#include "BLEDevice.h"
#include "BLEUtils.h"
#include "BLEBeacon.h"
#include "esp_sleep.h"
#define GPIO_DEEP_SLEEP_DURATION 10      // sleep x seconds and then wake up
RTC_DATA_ATTR static time_t last;        // remember last boot in RTC Memory
RTC_DATA_ATTR static uint32_t bootcount; // remember number of boots in RTC Memory
#ifdef __cplusplus
extern "C"
  uint8_t temprature_sens_read();
  //uint8_t g_phyFuns;
#ifdef __cplusplus
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
BLEAdvertising *pAdvertising;
struct timeval now;
#define BEACON_UUID "8ec76ea3-6668-48da-9866-75be8bc86f4d" // UUID 1 128-Bit (may use linux tool uuidgen or random numbers via https://www.uuidgenerator.net/)
void setBeacon()
  BLEBeacon oBeacon = BLEBeacon();
  oBeacon.setManufacturerId(0x4C00); // fake Apple 0x004C LSB (ENDIAN_CHANGE_U16!)
  oBeacon.setProximityUUID(BLEUUID(BEACON_UUID));
  oBeacon.setMajor((bootcount & 0xFFFF0000) >> 16);
  oBeacon.setMinor(bootcount & 0xFFFF);
  BLEAdvertisementData oAdvertisementData = BLEAdvertisementData();
  BLEAdvertisementData oScanResponseData = BLEAdvertisementData();
  oAdvertisementData.setFlags(0x04); // BR_EDR_NOT_SUPPORTED 0x04
  std::string strServiceData = "";
  strServiceData += (char)26;   // Len
  strServiceData += (char)0xFF; // Type
  strServiceData += oBeacon.getData();
  oAdvertisementData.addData(strServiceData);
  pAdvertising->setAdvertisementData(oAdvertisementData);
  pAdvertising->setScanResponseData(oScanResponseData);
  pAdvertising->setAdvertisementType(ADV_TYPE_NONCONN_IND);
void setup()
  Serial.begin(9600);
  gettimeofday(&now, NULL);
  Serial.printf("start ESP32 %d\n", bootcount++);
  Serial.printf("deep sleep (%lds since last reset, %lds since last boot)\n", now.tv_sec, now.tv_sec - last);
  last = now.tv_sec;
  // Create the BLE Device
  BLEDevice::init("");
  // Create the BLE Server
  // BLEServer *pServer = BLEDevice::createServer(); // <-- no longer required to instantiate BLEServer, less flash and ram usage
  pAdvertising = BLEDevice::getAdvertising();
  setBeacon();
  // Start advertising
  pAdvertising->start();
  Serial.println("Advertizing started...");
  delay(100);
  pAdvertising->stop();
  Serial.printf("enter deep sleep\n");
  esp_deep_sleep(1000000LL * GPIO_DEEP_SLEEP_DURATION);
  Serial.printf("in deep sleep\n");
void loop()
The error:
Processing wemos_d1_mini32 (platform: espressif32; board: wemos_d1_mini32; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/wemos_d1_mini32.html
PLATFORM: Espressif 32 1.12.4 > WeMos D1 MINI ESP32
Found 46 compatible libraries
|-- <ESP32 BLE Arduino> 1.0.1
Compiling .pio\build\wemos_d1_mini32\src\main.cpp.o
Compiling .pio\build\wemos_d1_mini32\liba2e\BLE\BLEBeacon.cpp.o
Compiling .pio\build\wemos_d1_mini32\liba2e\BLE\BLECharacteristic.cpp.o
Compiling .pio\build\wemos_d1_mini32\liba2e\BLE\BLECharacteristicMap.cpp.o
Compiling .pio\build\wemos_d1_mini32\liba2e\BLE\BLEClient.cpp.o
src\main.cpp: In function 'void setBeacon()':
src\main.cpp:69:17: error: 'class BLEAdvertising' has no member named 'setAdvertisementType'
*** [.pio\build\wemos_d1_mini32\src\main.cpp.o] Error 1
I’m sorry for posting essentially the same thing i just posted.
I can’t see a way to delete it.
Click the … button under the post, the’s a delete option which looks like a dustbin.
I checked ESP32_BLE_Arduino/BLEAdvertising.h at master · nkolban/ESP32_BLE_Arduino · GitHub which defines classes BLEAdvertisementData and BLEAdvertising.
The latter has no member named setAdvertisementType, it does have setAdvertisementData.
Cheers,
Norm.
Thanks Norm, but I can’t delete what you typed,
I’m working on another script now. I went into the library and added some members to the class, and those errors went away. So I guess the trick is finding the class in the library.
What data type could setAdvertisementType take?
A new one came though.
Has no class ‘begin’.
And I have a variable I can’t use, apparently.
It looks like setAdvertisementType is provided by the BLEAdvertising.h included as part of the arduino-esp32 board support package
It appears that the type should be one of the following
    ADV_TYPE_IND
    ADV_TYPE_DIRECT_IND_HIGH
    ADV_TYPE_SCAN_IND
    ADV_TYPE_DIRECT_IND_LOW
but I have no idea what they mean. According this, more study of BLE abstraction will make it all fall into place… Let me know if it does! :laughing: https://esp32.com/viewtopic.php?t=2267
I have several different DHT library folders. DHT.h was specified in this example sketch. I was looking at sensor libraryemphasized text**.
Now I have several of these threads open as tabs on my PC. I hope to emerge from the weekend with a grasp of ‘class’.
I have created a BLE peripheral beacon with a single “Hello World” service, and I was able to read that in nRF. I don’t think I know how to write back, because it’s in HEX. It says read/write, but there’s no connection so it shouldn’t work.
Now I’m looking to generate data with the DHT11 and serve that. Really, I want the BME 680 (Temp, Hum, Press, VOC), but I haven’t gotten that one to wok yet. Something in a library divides by zero.
Next, I’ll make a central and display the DHT11 data on OLED. And then I’ll switch from beacon to direct-connect BLE.
And then I will dance a little jig, because I’m two months behind due to the Arduino-PIO migration.
When I have my paired devices, I’ll publish a how-to with:
Make a beacon
Make a beacon reader
Make a dedicated pair.
Mesh is too far down on my list. Not going to start that for a while. What I want is a set of sensor pods and a central reader to collect data and publish a web page.
