Good morning!
I found a stock ticker program I like. I want to make it an ESP Now sender. It looks to me like it should work, but I get three errors, one for each stock I’m trying to look up. I got the API Key.
It looks to me like a query comes up empty.
“Fetching price for TSLA
Fetching resource from https://www.alphavantage.co/query?function=GLOBAL_QUOTE&symbol
=TSLAQITRTT5A746YIJBI
HTTPS GET failed with code -1
Failed to parse response to JSON with EmptyInput
Fetching price for NLY
=NLYQITRTT5A746YIJBI
Fetching price for BREW
=BREWQITRTT5A746YIJBI
Fetching resource from https://www.alphavantage.co/query?function=CURRENCY_EXCHANGE_R
ATE&from_currency=BTC&to_currency=USDQITRTT5A746YIJBI
Failed to parse response to JSON with EmptyInput”
Here’s the code:
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <ArduinoJson.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
#include <ESP8266HTTPClient.h>
#include <WiFiClientSecureBearSSL.h>
// Wifi credential information
const String kSsid = "TP-Link_7C28";
const String kPassword = "64411811";
// AlphaVantage API information, they have free tokens ;)
const String kApiUri = "https://www.alphavantage.co";
const String kApiBaseUri = "https://www.alphavantage.co/query?";
const String kApiStockPrice = "function=GLOBAL_QUOTE&";
const String kApiExchangeRate = "function=CURRENCY_EXCHANGE_RATE&";
const String kApiFromCurrency = "from_currency=BTC&";
// Note: we leave the & off of this one as the last piece is the kApiKey
const String kApiToCurrency = "to_currency=USD";
const String kApiSymbol = "symbol=";
const String kApiKey = "QITRTT5A746YIJBI";
// Define additional ticker symbols here
const String kTickerSymbols[] = {
"TSLA", //
"NLY", //
// Max document size that we can parse for JSON, resp from AV has about 10 vals
const size_t kMaxJsonDoc = 0x400;
StaticJsonDocument<kMaxJsonDoc> doc;
// Main loop pause
const size_t kDelay = 30000;
// Seconds to wait between POSTs to AlphaVantage
const size_t kStockPause = 15000;
// Blink delay for the lights
const size_t kBlinkDelay = 1000;
// SHA1 fingerprint of the sites certificate
const char *kAlphaVantageFingerprint = "C9 44 AD B9 48 6F 7C D1 64 5F ED 9B 49 53 56 88 DA FD FC 4B";
// Init the SSD1306 display
Adafruit_SSD1306 display = Adafruit_SSD1306();
// Init the ESP8266 Wifi Module
ESP8266WiFiMulti WiFiMulti;
void setup()
Serial.begin(9600);
Serial.println();
Serial.println("Stock Ticker Board v0.1");
Serial.print("Connecting to wifi: ");
Serial.print(kSsid);
// initialize with the I2C addr 0x3C (for the 128x32)
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
display.clearDisplay();
display.display();
display.setTextSize(1);
display.setTextColor(WHITE);
auto msg = "Connecting to " + kSsid;
display.print(msg);
display.setCursor(0, 0);
display.display();
delay(500);
WiFi.mode(WIFI_STA);
WiFiMulti.addAP(kSsid.c_str(), kPassword.c_str());
while (WiFiMulti.run() != WL_CONNECTED)
delay(500);
Serial.print(" .");
Serial.println();
Serial.print("Connected to ");
Serial.print(" with IP address: ");
display.setCursor(0, 15);
display.print("IP: " + WiFi.localIP().toString());
display.display();
delay(2000);
// Fetches a string response from a remote API endpoint URI
int getApiResponse(const String &uri, String &resp)
Serial.println("Fetching resource from " + uri);
std::unique_ptr<BearSSL::WiFiClientSecure> secure_client(new BearSSL::WiFiClientSecure);
secure_client->setFingerprint(kAlphaVantageFingerprint);
secure_client->setTimeout(3000);
HTTPClient https;
auto ret = https.begin(*secure_client, uri);
if (!ret)
Serial.println("Failed to connect to URI with " + String(ret));
return 1;
auto status = https.GET();
if (status != HTTP_CODE_OK)
Serial.println("HTTPS GET failed with code " + String(status));
return status;
resp = https.getString();
return status;
void blink()
delay(kBlinkDelay);
delay(kBlinkDelay);
void loop()
// Blink to indicate we're about to fetch new stocks
blink();
// We fetch stock values in a loop around the ticker symbols, defined above
for (const auto sym : kTickerSymbols)
Serial.println("Fetching price for " + sym);
// Perform the API request
String resp;
String uri = kApiBaseUri + kApiStockPrice + kApiSymbol + sym + kApiKey;
auto ret = getApiResponse(uri, resp);
if (ret == 1)
Serial.println("Fetch remote resource failed. Continuing");
delay(kStockPause);
continue;
// Parse the response into a JSON object
auto err = deserializeJson(doc, resp);
if (err)
Serial.println("Failed to parse response to JSON with " + String(err.c_str()));
delay(kStockPause);
continue;
// We display the price
auto quote = doc["Global Quote"];
auto quote_msg = sym + ": " + quote["05. price"].as<String>() + ", " +
quote["09. change"].as<String>() + " (" +
quote["10. change percent"].as<String>() + ")";
Serial.println(quote_msg);
display.print(quote_msg);
display.display();
delay(kStockPause);
// Lastly, fetch the USD -> BTC exchange rate, for funsies
String resp;
String uri = kApiBaseUri + kApiExchangeRate + kApiFromCurrency +
kApiToCurrency + kApiKey;
if (err)
else
auto er = doc["Realtime Currency Exchange Rate"];
auto msg = er["1. From_Currency Code"].as<String>() + " -> " +
er["3. To_Currency Code"].as<String>() + ": " +
er["5. Exchange Rate"].as<String>();
Serial.println(msg);
display.print(msg);
display.display();
delay(kDelay);
