The situation has resolved itself, but I still want to understand this ‘backtrace’ stuff.
My ESP Now sender code used millis, and reported the last reading in millis. I wanted to change that to formattedTime, so I added in all that stuff:
#include <NTPClient.h>
#include <WiFiUdp.h>
#define SEALEVELPRESSURE_HPA (1013.25 + 10)
#define NTP_OFFSET -18000 // In seconds
#define NTP_INTERVAL 60 * 1000 // In miliseconds
#define NTP_ADDRESS "pool.ntp.org"
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, NTP_ADDRESS, NTP_OFFSET, NTP_INTERVAL);
timeClient.begin();
timeClient.update();
String formattedTime = timeClient.getFormattedTime();
String str = formattedTime;
Serial.print(F("Last reading = "));
Serial.println(str);
Now I get this backtrace stuff: (There is no line 374)
Rebooting...
KR�"�B
�fQs�C)���R�^�L�o���assertion "Invalid mbox" failed: file "/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/lwip/lwip/src/api/tcpip.c", line 374, function: tcpip_send_msg_wait_sem
abort() was called at PC 0x400f0707 on core 1
ELF file SHA256: 0000000000000000
Backtrace: 0x40088e68:0x3ffb1d80 0x400890e5:0x3ffb1da0 0x400f0707:0x3ffb1dc0 0x4011cf27:0x3ffb1df0 0x4011c7bd:0x3ffb1e20 0x4011c970:0x3ffb1e40 0x4011371a:0x3ffb1e80 0x400d1c79:0x3ffb1ea0 0x400d1d5d:0x3ffb1ee0 0x40145e11:0x3ffb1f10 0x400d389b:0x3ffb1f30 0x400d093e:0x3ffb1f50 0x400d621a:0x3ffb1fb0 0x4008a0f6:0x3ffb1fd0
Rebooting...
KR��␜Q��␜!�(E��␐<�␖F
Sender code:
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp32-esp-now-wi-fi-web-server/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
#include <esp_now.h>
#include <esp_wifi.h>
#include <WiFi.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include "Adafruit_SGP30.h"
#include "Adafruit_VEML6070.h"
WiFiUDP ntpUDP;
Adafruit_VEML6070 uv = Adafruit_VEML6070();
Adafruit_BME680 bme; // I2C
// Set your Board ID (ESP32 Sender #1 = BOARD_ID 1, ESP32 Sender #2 = BOARD_ID 2, etc)
#define BOARD_ID 2
// MAC Address of the receiver
uint8_t broadcastAddress[] = {0x3C, 0x61, 0x05, 0x12, 0x84, 0x28};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message
int id;
float completed;
float temperature;
float humidity;
float pressure;
float altitude;
float LPG;
float CO;
float CO2;
float NH3;
float NO2;
float VOC;
float UV;
float TVOC;
float smoke;
float H2;
float EtOH;
int readingId;
} struct_message;
// Create a struct_message called myData
struct_message myData;
unsigned long previousMillis = 0; // Stores last time temperature was published
const long interval = 10000; // Interval at which to publish sensor readings
unsigned int readingId = 0;
// Insert your SSID
constexpr char WIFI_SSID[] = "TP-Link_7C28";
int32_t getWiFiChannel(const char *ssid)
if (int32_t n = WiFi.scanNetworks())
for (uint8_t i = 0; i < n; i++)
if (!strcmp(ssid, WiFi.SSID(i).c_str()))
return WiFi.channel(i);
return 0;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status)
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void setup()
Serial.begin(9600);
uv.begin(VEML6070_1_T);
timeClient.begin();
// Init Serial Monitor
while (!Serial)
Serial.println(F("BME680 test"));
if (!bme.begin())
Serial.println(F("BME680 not found"));
while (1)
pinMode(A0, INPUT);
// Set device as a Wi-Fi Station and set channel
WiFi.mode(WIFI_STA);
int32_t channel = getWiFiChannel(WIFI_SSID);
WiFi.printDiag(Serial); // Uncomment to verify channel number before
esp_wifi_set_promiscuous(true);
esp_wifi_set_channel(channel, WIFI_SECOND_CHAN_NONE);
esp_wifi_set_promiscuous(false);
WiFi.printDiag(Serial); // Uncomment to verify channel change after
// Init ESP-NOW
if (esp_now_init() != ESP_OK)
Serial.println("Error initializing ESP-NOW");
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
esp_now_peer_info_t peerInfo;
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK)
Serial.println("Failed to add peer");
return;
// Set up oversampling and filter initialization
bme.setTemperatureOversampling(BME680_OS_8X);
bme.setHumidityOversampling(BME680_OS_2X);
bme.setPressureOversampling(BME680_OS_4X);
bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
bme.setGasHeater(320, 150); // 320*C for 150 ms
void loop()
float UV=0;
unsigned long currentMillis = millis();
if (currentMillis - previousMillis >= interval)
if (!bme.endReading())
Serial.println(F("Failed to complete reading :("));
return;
Serial.print(F("Reading completed at "));
Serial.println(millis());
float completed = millis();
//float altitude = bme.readAltitude(SEALEVELPRESSURE_HPA) + 103;
float sensorValue = 0;
float sensorVolts = 0;
for (int i = 0; i < 100; i++)
sensorValue = sensorValue + analogRead(A0); // read analog input pin 0
sensorValue = sensorValue / 100; // get average reading
sensorVolts = sensorValue / 1024 * 5.0; // convert to voltage
float smoke = sensorVolts / 20;
Serial.print(F("Temperature = "));
Serial.print(bme.temperature, 0);
Serial.println(F(" *C"));
Serial.print(F("Humidity = "));
Serial.print(bme.humidity, 0);
Serial.println(F(" %"));
Serial.print(F("UV = "));
Serial.print(UV, 0);
Serial.print("Smoke: ");
Serial.println(smoke);
if (smoke > 1.0)
Serial.println("Smoke Detected!");
// Save the last time a new reading was published
previousMillis = currentMillis;
// Set values to send
myData.id = BOARD_ID;
myData.completed = completed;
myData.temperature = (bme.temperature);
myData.humidity = (bme.humidity);
myData.pressure = (bme.pressure);
//myData.altitude = (altitude);
myData.smoke = smoke;
myData.LPG = 0;
myData.UV = UV;
myData.CO = 0;
myData.CO2 = 0;
myData.NH3 = 0;
myData.NO2 = 0;
myData.VOC = 0;
myData.TVOC = 0;
myData.H2 = 0;
myData.EtOH = 0;
myData.readingId = readingId++;
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *)&myData, sizeof(myData));
if (result == ESP_OK)
Serial.println("Sent with success");
else
Serial.println("Error sending the data");
delay(5000);
