Processing ETHERNET (platform: espressif32; board: esp32dev; framework: arduino)
CONFIGURATION:
PLATFORM: Espressif 32 (6.5.0) > Espressif ESP32 Dev Module
- framework-arduinoespressif32 @ 3.20014.231204 (2.0.14)
LDF Modes: Finder ~ deep+, Compatibility ~ soft
Found 36 compatible libraries
|-- TFT_eSPI @ 2.5.43
|-- GFX Library for Arduino @ 1.4.1
|-- ESP32Ping @ 1.7.0
|-- SPI @ 2.0.0
|-- Ethernet @ 2.0.0
|-- EEPROM @ 2.0.0
|-- WiFi @ 2.0.0
Archiving .pio\build\ETHERNET\libbd4\libWiFi.a
Archiving .pio\build\ETHERNET\libc71\libESP32Ping.a
Compiling .pio\build\ETHERNET\libc2a\Ethernet\ETH.cpp.o
In file included from C:/Users/Username/.platformio/packages/framework-arduinoespressif32/libraries/Ethernet/src/ETH.cpp:24:
C:/Users/Username/.platformio/packages/framework-arduinoespressif32/libraries/Ethernet/src/ETH.h:27:10: fatal error: WiFi.h: No such file or directory
* Looking for WiFi.h dependency? Check our library registry!
* CLI > platformio lib search "header:WiFi.h"
* Web >...registry.platformio.org/search?q=header:WiFi.h
#include "WiFi.h"
compilation terminated.
Archiving .pio\build\ETHERNET\lib998\libEEPROM.a
Compiling .pio\build\ETHERNET\FrameworkArduino\FirmwareMSC.cpp.o
Compiling .pio\build\ETHERNET\FrameworkArduino\FunctionalInterrupt.cpp.o
Compiling .pio\build\ETHERNET\FrameworkArduino\HWCDC.cpp.o
Compiling .pio\build\ETHERNET\FrameworkArduino\HardwareSerial.cpp.o
*** [.pio\build\ETHERNET\libc2a\Ethernet\ETH.cpp.o] Error 1
the content of platform.ini :
[env:ETHERNET]
upload_port = COM9
monitor_port = COM[9]
lib_ldf_mode = deep+
lib_extra_dirs = ~/Documents/Arduino/libraries, /lib
board_build.partitions = no_ota.csv
-I$PROJECT_DIR/include/
-D USER_SETUP_LOADED=1
-D TOUCH_SETUP_LOADED=1
-D ILI9488_DRIVER=1
-D TFT_MOSI=14
-D TFT_MISO=1
-D TFT_SCLK=12
-D TFT_CS=2
-D TFT_DC=15
-D TFT_RST=4
-D LOAD_GLCD=1
-D LOAD_FONT2=1
-D LOAD_FONT4=1
-D LOAD_FONT6=1
-D LOAD_FONT8=1
-D TOUCH_CS=3
-D SPI_FREQUENCY=27000000
-D SPI_READ_FREQUENCY=16000000
-D SPI_TOUCH_FREQUENCY=2500000
-D ETH_CLK_MODE=ETH_CLOCK_GPIO17_OUT
-D ETH_PHY_POWER=16
-D ETH_PHY_TYPE=ETH_PHY_LAN8720
-D ETH_PHY_ADDR=1
-D ETH_PHY_MDC=23
-D ETH_PHY_MDIO=18
-D LINK_LED=35
-D EEPROM_SIZE=512
bodmer/TFT_eSPI@^2.4.74
moononournation/GFX Library for Arduino@^1.2.6
marian-craciunescu/ESP32Ping@^1.7
It seems PlatformIO cannot detect the the Ethernet library has a dependency to the WiFi library in this instance. Can you try removing your lib_ldf_mode = deep+ or testing all other values for it?
here the other error when i tried to removed lib_ldf_mode = deep+
Compiling .pio\build\ETHERNET\lib196\GFX Library for Arduino\canvas\Arduino_Canvas.cpp.o
Compiling .pio\build\ETHERNET\lib196\GFX Library for Arduino\canvas\Arduino_Canvas_3bit.cpp.o
Compiling .pio\build\ETHERNET\lib196\GFX Library for Arduino\canvas\Arduino_Canvas_Indexed.cpp.o
In file included from .pio/libdeps/ETHERNET/GFX Library for Arduino/src/Arduino_GFX_Library.h:38,
from .pio/libdeps/ETHERNET/GFX Library for Arduino/src/Arduino_GFX_Library.cpp:1:
.pio/libdeps/ETHERNET/GFX Library for Arduino/src/databus/Arduino_Wire.h:7:10: fatal error: Wire.h: No such file or directory
* Looking for Wire.h dependency? Check our library registry!
* CLI > platformio lib search "header:Wire.h"
* Web > https://registry.platformio.org/search?q=header:Wire.h
#include <Wire.h>
*** [.pio\build\ETHERNET\lib196\GFX Library for Arduino\Arduino_GFX_Library.cpp.o] Error 1
========================================= [FAILED] Took 17.40 seconds =========================================
try adding -D CONFIG_ETH_ENABLED
