Hi there
I have been having problems running Expressif ESP32 UART Serial examples in VScode & PlatformIO and have been seeing the following compilation error.
void uart2_init(void) {
const uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
.source_clk = UART_SCLK_APB,
Error Message:
class “uart_config_t” has no field “source_clk”
identifier “UART_SCLK_APB” is undefined
It appears that the latest version of the ESP32 Platform (3.3.1) is using the deprecated use_ref_tick method in the uart_config_t definition.
As below;
Platformio ESP32 driver/uart.h file
* @brief UART configuration parameters for uart_param_config function
typedef struct {
int baud_rate; /*!< UART baud rate*/
uart_word_length_t data_bits; /*!< UART byte size*/
uart_parity_t parity; /*!< UART parity mode*/
uart_stop_bits_t stop_bits; /*!< UART stop bits*/
uart_hw_flowcontrol_t flow_ctrl; /*!< UART HW flow control mode (cts/rts)*/
uint8_t rx_flow_ctrl_thresh; /*!< UART HW RTS threshold*/
bool use_ref_tick; /*!< Set to true if UART should be clocked from REF_TICK */
} uart_config_t;
Espressif ESP32 Documentation
typedef struct {
union {
uart_sclk_t source_clk; /*!< UART source clock selection */
**bool use_ref_tick __attribute__((deprecated)); /*!< Deprecated method to select ref tick clock source, set source_clk field instead */**
} uart_config_t;
