I’m very pleased that PlatformIO recognize AdaFruit ESP32 Qualia S3 - RGB66 board. And I’ve transferred my Arduino Coded project to VSCode/PlatformIO. But I had an error about Flash Size.
Before I’ve opened the menuconfig, It was set to 2MB. And it gives this warning.
I’ve upload the project without problem, and I could not get calloc functions to run. So I’ve changed the flash size to 16MB in menuconfig and warning disappeared. Did I do it right? Am I missing something ?
Hello again,
I’ve deleted the project and started new again today. Build had no error, but Upload says the Flash Size is mismatch. Here is the Screen data
Processing adafruit_qualia_s3_rgb666 (platform: espressif32; board: adafruit_qualia_s3_rgb666; framework: espidf)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/adafruit_qualia_s3_rgb666.html
PLATFORM: Espressif 32 (6.5.0) > Adafruit Qualia ESP32-S3 RGB666
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
DEBUG: Current (cmsis-dap) External (cmsis-dap, esp-bridge, esp-builtin, esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
- framework-espidf @ 3.50102.0 (5.1.2)
- tool-cmake @ 3.16.4
- tool-idf @ 1.0.1
- tool-mconf @ 1.4060000.20190628 (406.0.0)
- tool-mkfatfs @ 2.0.1
- tool-ninja @ 1.9.0
- tool-riscv32-esp-elf-gdb @ 11.2.0+20220823
- tool-xtensa-esp-elf-gdb @ 11.2.0+20230208
- toolchain-esp32ulp @ 1.23500.220830 (2.35.0)
- toolchain-riscv32-esp @ 12.2.0+20230208
- toolchain-xtensa-esp32s3 @ 12.2.0+20230208
Warning! Flash memory size mismatch detected. Expected 16MB, found 2MB!
Please select a proper value in your `sdkconfig.defaults` or via the `menuconfig` target!
Found 3 compatible libraries
|-- MyPCA9554
|-- MyUtils
|-- MyWire
Retrieving maximum program size .pio\build\adafruit_qualia_s3_rgb666\firmware.elf
Checking size .pio\build\adafruit_qualia_s3_rgb666\firmware.elf
RAM: [ ] 4.0% (used 13136 bytes from 327680 bytes)
Flash: [== ] 23.4% (used 245373 bytes from 1048576 bytes)
AVAILABLE: cmsis-dap, esp-bridge, esp-builtin, esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
Looking for upload port...
Auto-detected: COM4
Now, Last time I've used menuconfig. This time I only update the sdkconfig file by hand.
# Serial flasher config
# CONFIG_ESPTOOLPY_NO_STUB is not set
# CONFIG_ESPTOOLPY_OCT_FLASH is not set
CONFIG_ESPTOOLPY_FLASH_MODE_AUTO_DETECT=y
# CONFIG_ESPTOOLPY_FLASHMODE_QIO is not set
# CONFIG_ESPTOOLPY_FLASHMODE_QOUT is not set
CONFIG_ESPTOOLPY_FLASHMODE_DIO=y
# CONFIG_ESPTOOLPY_FLASHMODE_DOUT is not set
CONFIG_ESPTOOLPY_FLASH_SAMPLE_MODE_STR=y
CONFIG_ESPTOOLPY_FLASHMODE="dio"
# CONFIG_ESPTOOLPY_FLASHFREQ_120M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_80M=y
# CONFIG_ESPTOOLPY_FLASHFREQ_40M is not set
# CONFIG_ESPTOOLPY_FLASHFREQ_20M is not set
CONFIG_ESPTOOLPY_FLASHFREQ_80M_DEFAULT=y
CONFIG_ESPTOOLPY_FLASHFREQ="80m"
# CONFIG_ESPTOOLPY_FLASHSIZE_1MB is not set
#CONFIG_ESPTOOLPY_FLASHSIZE_2MB=y
# CONFIG_ESPTOOLPY_FLASHSIZE_4MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_8MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE_16MB=y # is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_32MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_64MB is not set
# CONFIG_ESPTOOLPY_FLASHSIZE_128MB is not set
CONFIG_ESPTOOLPY_FLASHSIZE="16MB"
# CONFIG_ESPTOOLPY_HEADER_FLASHSIZE_UPDATE is not set
CONFIG_ESPTOOLPY_BEFORE_RESET=y
# CONFIG_ESPTOOLPY_BEFORE_NORESET is not set
CONFIG_ESPTOOLPY_BEFORE="default_reset"
CONFIG_ESPTOOLPY_AFTER_RESET=y
# CONFIG_ESPTOOLPY_AFTER_NORESET is not set
CONFIG_ESPTOOLPY_AFTER="hard_reset"
CONFIG_ESPTOOLPY_MONITOR_BAUD=115200
# end of Serial flasher config
Build is ok. Upload has no error nor warnings. Board seems to run. Because I can get data from serial port wia "Printf" but here is the problem :
Hello world!
my_wire_create
Initialising I2C Master: sda=8 scl=18 freq=1000000
MyWire ready!
PCA9554 found
PCA9554 Setup Done!
Panel Create
e[0;31mE (1079) lcd_panel.rgb: lcd_rgb_panel_alloc_frame_buffers(156): no mem for frame buffere[0m
e[0;31mE (1079) lcd_panel.rgb: esp_lcd_new_rgb_panel(285): alloc frame buffers failede[0m
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x420034f5 PS : 0x00060730 A0 : 0x82003afe A1 : 0x3fc9a560
A2 : 0x3fc9bdc8 A3 : 0x3c020604 A4 : 0x3c020b34 A5 : 0x00000437
A6 : 0x3c020604 A7 : 0x3c020de4 A8 : 0x00000000 A9 : 0x3fc9a500
A10 : 0x420122b8 A11 : 0x3c020604 A12 : 0x3c020b34 A13 : 0x3fc9a560
A14 : 0x3fc9a540 A15 : 0x0000000c SAR : 0x00000004 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x400556d5 LEND : 0x400556e5 LCOUNT : 0xfffffffa
Backtrace: 0x420034f2:0x3fc9a560 0x42003afb:0x3fc9a580 0x4200188f:0x3fc9a5c0 0x420019b0:0x3fc9a690 0x4037de10:0x3fc9a8a0 0x4037da09:0x3fc9a8d0
" alloc frame buffers failed " caused because Flash size or something else ?
I wish those options are done with the PlatformIO at first place. Because when I select a board. I assume it was already configured all, and rest is only coding. But anyway, I’m happy now. I’ll start to code asap.
