I’m trying to use the Debugger in the mega2560 and get the error “Could not find the specified task” when I click the “Run and Debug” button for my project. I also have the warning listed below.
I’m having a hard time finding documentation on how to setup for debug. Most documentation and examples don’t mention you have to build for Debug mode. I added that in platform.ini thinking it was needed. Is there a document or example that fully describes what has to be done for Debug? Especially for a mega2560 or similar?
What have I done of not done that is the problem?
Warning in Output:
Error: The PlatformIO task detection didn’t contribute a task for the following configuration:
“type”: “PlatformIO”,
“task”: “Pre-Debug”,
“problemMatcher”: [
“$platformio”
“label”: “PlatformIO: Build in debug mode”
The task will be ignored.
My platform.ini file is:
[platformio]
default_envs = megaatmega2560Debug
[env]
[env:due]
platform = atmelsam
board = due
[env:megaatmega2560Release]
board = megaatmega2560
[env:megaatmega2560Debug]
build_type = debug
build_flags = -D DEBUG=1
debug_tool = avr-stub
debug_port = /dev/cu.usbserial-DT03ZORA
; GDB stub implementation
jdolinay/avr-debugger @ ~1.1
My launch.json is:
“version”: “0.2.0”,
“configurations”: [
“type”: “platformio-debug”,
“request”: “launch”,
“name”: “PIO Debug”,
“executable”: “/Users/zac/Documents/PlatformIO/Projects/RadarRTC/.pio/build/megaatmega2560Debug/firmware.elf”,
“projectEnvName”: “megaatmega2560Debug”,
“toolchainBinDir”: “/Users/zac/.platformio/packages/toolchain-atmelavr/bin”,
“internalConsoleOptions”: “openOnSessionStart”,
“preLaunchTask”: {
“task”: “Pre-Debug (megaatmega2560Debug)”
“name”: “PIO Debug (skip Pre-Debug)”,
My tasks.json:
“version”: “2.0.0”,
“tasks”: [
“task”: “Build”,
“problemMatcher”: [
“$platformio”
“group”: “build”,
“label”: “PlatformIO: Build”
