PlatformIO upload button on VS Code PlatformIO taskbar: how to set to upload without building the application
Hello guys, I want to know if there is a way to disable building the application clicking on the upload button located in the PlatformIO taskbar on VS Code.
In practice, I would prefer to click on build button to build and click on upload to just upload.
Is it possible? And if possible… how?
Thanks.
Why would one not want to upload the latest code written it in the editor during development?
In any case, this was already answered in Upload Latest build without a Compile/Link - #4 by ivankravets.
This is a commandline option. The button cannot be reconfigured.
You can create your own task with custom upload command. See Custom Targets — PlatformIO latest documentation
  1. It is stupid to have a button that builds all the application and another that builds all and then uploads the application. I am in the embedded development sinc the '80s and it is just loosing time. If I want to build all the application I press the build. It is time lost also if I need to upload the application on some devices.
  2. I read that post, I was looking if is possible to modify the button action.
Just add
extra_scripts = upload_no_build.py
to the platformio.ini and upload_no_build.py with
Import("env")
env.AddCustomTarget(
    "uploadnobuild",
    None,
    'pio run -e %s -t nobuild -t upload' %
        env["PIOENV"],
    title="Uploads without building"
and you will have
grafik
ok this is a new task I have to add to each project
Exactly, in this implementation style yes.
I agree with @maxgerhardt on this.
There are many times you add / modify code and want to compile just to see if there are any issues first. Or want to check how much ram / flash was used by pulling in new code sources. An “Upload” button should do what its named.
Simple pio run -t nobuild -t upload
