HI,
I am quite new to PlatformIO.
I start with Waveshare ESp32-S3-touch-LCD-7 monitor, for this project I use the following libraries:
https://github.com/esp-arduino-libs/ESP32_Display_Panel.git#v0.1.6
https://github.com/esp-arduino-libs/ESP32_IO_Expander.git#v0.0.3
lvgl/lvgl@8.3.11
iamfaraz/Waveshare_ST7262_LVGL @ ^0.1
I receive this linker errors:
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/lib/esp32s3/no-rtti\libc.a(libc_a-getentropyr.o):(.literal+0x4): warning: _getentropy is not implemented and will always fail
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:/Users/s.dolciotti/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/qio_opi\libesp_system.a(startup.c.obj):(.literal.__esp_system_init_fn_init_components0+0x8): undefined reference to `_Unwind_SetEnableExceptionFdeSorting'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:/Users/s.dolciotti/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/qio_opi\libesp_system.a(startup.c.obj): in function `__esp_system_init_fn_init_components0':
/home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp_system/startup.c:497:(.text.__esp_system_init_fn_init_components0+0x1e): undefined reference to `_Unwind_SetEnableExceptionFdeSorting'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:/Users/s.dolciotti/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/lib\libnewlib.a(reent_init.c.obj):(.iram1.0.literal+0x4): undefined reference to `_cleanup_r'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:/Users/s.dolciotti/.platformio/packages/framework-arduinoespressif32-libs/esp32s3/lib\libnewlib.a(newlib_init.c.obj):(.data.s_stub_table+0x98): undefined reference to `_cleanup_r'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: .pio/build/ESP-LCD/src/main.cpp.o:(.literal._Z5setupv+0xc): undefined reference to `ESP_Panel::ESP_Panel()'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: .pio/build/ESP-LCD/src/main.cpp.o:(.literal._Z5setupv+0x10): undefined reference to `ESP_Panel::init()'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: .pio/build/ESP-LCD/src/main.cpp.o: in function `setup()':
C:\Progetti\ESP32\IOTHome/src/main.cpp:17:(.text._Z5setupv+0x40): undefined reference to `ESP_Panel::ESP_Panel()'
C:/Users/s.dolciotti/.platformio/packages/toolchain-xtensa-esp-elf/bin/../lib/gcc/xtensa-esp-elf/13.2.0/../../../../xtensa-esp-elf/bin/ld.exe: C:\Progetti\ESP32\IOTHome/src/main.cpp:18:(.text._Z5setupv+0x48):
*** [.pio\build\ESP-LCD\firmware.elf] Error 1
this is my platformIO.ini
[env:ESP-LCD]
board = ESP-LCD
platform_packages =
platformio/framework-arduinoespressif32@https://github.com/espressif/arduino-esp32.git#3.0.3
platformio/framework-arduinoespressif32-libs@https://github.com/esp-arduino-libs/arduino-esp32-sdk.git#high_perf/v3.0.3
upload_speed = 921600
board_upload.flash_size = 8MB
board_build.f_flash = 80000000L
board_upload.maximum_size=8388608
-D BOARD_HAS_PSRAM
; -DARDUINO_USB_CDC_ON_BOOT=0 ; If using UART port
-DARDUINO_USB_CDC_ON_BOOT=1 ; If using USB port
-DCORE_DEBUG_LEVEL=1 ; Set to `5` for full debug output, `0` for none
-DLV_CONF_INCLUDE_SIMPLE
-DLV_LVGL_H_INCLUDE_SIMPLE
-I src
board_build.arduino.memory_type = qio_opi
board_build.flash_mode = qio
board_build.psram_type = opi
lvgl/lvgl@8.3.11
bblanchon/ArduinoJson @ ^7.3.0
adafruit/Adafruit_VL53L0X @ ^1.2.4
and this is my test main:
#include <ESP_Panel_Library.h>
//#include <Waveshare_ST7262_LVGL.h>
#include <lvgl.h>
#include "../include/Debug.hpp"
initDebug();
printDebug("Initialize display and touchscreen", true);
//lcd_init();
ESP_Panel *panel = new ESP_Panel();
panel->init();
printDebug("Create UI", true);
//Lock the mutex due to the LVGL APIs are not thread-safe
//lvgl_port_lock(-1);
* Or try out a demo.
* Don't forget to uncomment header and enable the demos in `lv_conf.h`. E.g. `LV_USE_DEMOS_WIDGETS`
//lv_demo_widgets();
// lv_demo_benchmark();
// lv_demo_music();
// lv_demo_stress();
//Release the mutex
//lvgl_port_unlock();
delay(500);
Thanks for the help in advance.
