PlatformIO undefined reference to library
I am making my own .cpp and .h files in /include folder, putting the declarations in .h files and definitions in .cpp files.
Here is the folder structure
- include
   |- filters
       |- lowpass_filter.h
       |- lowpass_filter.cpp
       |- bandpass_filter.h
       |- bandpass_filter.cpp
   |- board.h
   |- power.h
   |- power.cpp
VS Code intellisense detects those .cpp files easily.
But when I compile, it says undefined reference. When I put the definitions in .h files as well, and remove .cpp files, it works perfectly.
Is there a fix for that?
And in which folder are those files? They must be in src/ or in a new folder in lib/.
Yes, they are in lib/
Did you follow the documented folderstructure of
- lib
   |- YourLibraryName
       |- LibraryFile.h
       |- LibraryFile.cpp
or did you put them directly in lib (which is wrong)?
Okay I just checked, they are in include folder, not lib.
This is the structure
- include
   |- filters
       |- lowpass_filter.h
       |- bandpass_filter.h
   |- board.h
   |- power.h
   |- power.cpp
It has the files placed both the wrong and right ways. Both do not work.
Edit:
Even after putting the .h and .cpp files in relevant folders like you suggested, it gives the same error. And by the way I’m trying to compile for an ESP32, if that matters.
Files in include/ are not compiled – try moving everything from include/ in src/.
