Since a while (i don’t know, if it appears with a patch or something… didn’t use PIO for some time) i can’t upload code to my ESP32-boards any more.
Running VSCode with Ubuntu Linux, PIO always tries to upload code to /dev/cu.SLAB_USBtoUART (which is the standard port for Mac, as my research showed?) instead of /dev/ttyUSB0.
Adding “upload_port = /dev/ttyUSB0” in the platformio.ini does change just as little as un- and reinstalling VSC and/or PIO (with also deleting the settings in my /~ Directory).
Uploading the code with Arduino IDE works well, so it shouldn’t be a driver-related problem.
Does anyone have a solution for this?
