Does anyone know an instruction on how to add a new board: Arduino Portenta H7?
I was following this but got an error:
“Error: Could not load broken JSON: ~/.platformio/boards/h7.json”
Is there a place to request adding new board to PlatformIO?
Thanks!
Also, it involves more than adding a board defintion for the Portenta H7. You would need to add the Arduino core packages as well, with the appropriate builder script for it.
If I’m correct then GitHub - arduino/ArduinoCore-mbed is the core for the board? If yes, that’s the same core as for the nano33ble, so a lot may be re-used here
Wow, thanks for the direction! Yes the H7 uses the same mbed core with nano33ble. The ArduinoCore-mbed already supports the H7. Appreciate any direction on how to adapt the platform.py.
Below is my current h7.json. Looks like you’re pointing to exactly where I need to change platform.py.
My platformio.ini is pretty simple (see below). Yes I had to add some python code to the platform-ststm32. Basically copy & paste from the nano33ble. (Thanks to your suggestion! Saved me a lot of time )
Yeah I love it to be upstreamed support. One problem before submitting: uploading fails. Portenta H7 uses dfu-utils but dfu-util doesn’t know how to DFU the H7. Do you know where should I add a few commands before dfu-utils is called?
Hm first of all you should try reproducing what the Arduino IDE does on the commandline.
So if you have a compiled firmware for the portenta_h7m7 environment (PS: The space after env: is kinda weird and might end up in the pathname), the Arduino IDE would do something like
Try and open a PlatformIO CLI, pio run -e portenta_h7m7 to compile the firmware and then the command above but prefixed with the path to the dfu-util, which should be C:\Users\<user>\.platformio\packages\tool-dfuutil\bin. The board has to be put the board into DFU bootloader mode of course, so you should see something like
in the device manager.
What does dfu-util output then?
If the dfu-util version is too old, it can still be replaced with platform_packages = tool-dfuutil@somenewsource.zip.
Yeah, you’re right. Here’s the commands sequence that work for me:
pio run -d coreM7
stty -f /dev/cu.usbmodem1424201 1200
sleep 1
dfu-util —-device 0x2341:0x035b -D coreM7/.pio/build/h7m7/firmware.bin -a0 --dfuse-address=0x08040000:leave
stty -f /dev/cu.usbmodem1424201 1200 is to bring the Arduino to DFU mode. Looks like we also need to get the serial port string from platformIO. Then we had to wait a bit before calling dfu-util. I don’t like sleep in the code though. How do you think? Maybe polling for USB enumeration?
Here’s the output of dfu-util with: pio run -t upload -d coreM7
Looks like dfu-util doesn’t bring the chip to DFU mode, so we need to add commands to do make sure the board is in DFU mode before calling dfu-util.
AVAILABLE: blackmagic, cmsis-dap, dfu, jlink, mbed, stlink
CURRENT: upload_protocol = dfu
Uploading .pio/build/portenta_h7m7/firmware.bin
dfu-util 0.9
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2020 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
dfu-util: No DFU capable USB device available
*** [upload] Error 74
PS: let me know if you’d like me to push the change somewhere. Not sure if you had the board to try.
Ah indeed, that’s a nifty trick by the booloader / firmware – it detects that the USB-CDC serial is opened at 1200 baud and can do special logic then, aka rebooting into DFU mode. PlatformIO can do this too, and also has logic to wait for a new upload port then. But usually a COM port, not a new USB device I think.
The Atmel-SAM boards typically use this since the bootloader BOSSAC also behaves the same way with a ‘magic touch’.
So maybe adding those would help, too. (Or temporarily stty -f /dev/cu.usbmodem1424201 1200 before upload via PlatformIO)
Hm let’s dig into this then. First of all, with pio run -e portenta_h7m7 -t upload -v (or just “Advanced → Verbose Upload” in the VSCode project tasks), you’ll see the full invocation line that PlatformIO does for uploading. Can you post that?
Then it can be compared on what parts aren’t like the command that does work.
Is the code responsible for taking the information of the board’s JSON file and turning it into the command that’ll be executed for the DFU upload, btw.
An apparent problem is e.g. that it already hardcodes -a0 which would make upload to the M4 core that sits on interface number 1 impossible, without a code change in the code above plus a new field in the board’s JSON file to get that information from, per-board.
two attributes should be set too in the board’s JSON file I think, but with offset_address adapted to 0x08040000 for the M7 and 0x08100000 for the M4. Maybe the native_usb even does the trick so that it waits for a new USB device of a certain VID/PID instead of a new serial port.
