Hi. I am developing firmware for the OpenLog Artemis board. I have been doing this in the Arduino IDE, but as my firmware grows in complexity, I am finding it hard to keep track of things. Furthermore, the compilation process is painfully slow.
I was trying to see if I can port my code to PlatformIO, but it looks like the OpenLog Artemis is not supported. Code complied in PlatformIO does not upload. I get an error saying “No device found at COMxx”.
@siva82kb I managed to get PlatformIO working with my Sparkfun Artemis Global Tracker (AGT), which has an Artemis module at its core. It was fiddley but I made a bunch of notes as I went, I’ll paste them below. Hopefully you can do similar and get it working on the OpenLog Artemis, I have one of those and would like to be able to drive it from PlatformIO too, but haven’t tried yet.
Here are my notes for the AGT board under PlatformIO.
Good Luck,
Paul
The Artemis processor/board is not officially supported but when I was looking at this project
and they were doing it I thought I would give it a shot.
They were also specifically using the v1.0 core, not the v2.0 (MBed based) one I had read about being such a problem.
I followed a combination of the instructions on the above page and this one from the actual project that lets you do this in the first place.
DONT FORGET TO Add platform_packages = framework-arduinoapollo3@1.2.3 to platformio.ini
Everything worked except for when I went to compile the test_apollo3 example I got
Linking .pio/build/SparkFun_Artemis_Module/program
arm-none-eabi-g++: error: PlatformIO: No such file or directory
arm-none-eabi-g++: error: Projects/test_apollo3/.pio/build/SparkFun_Artemis_Module/program.map: No such file or directory
*** [.pio/build/SparkFun_Artemis_Module/program] Error 1
I did some digging and it turns out the g++ compiler does not handle spaces in the project folder path, and as my projects were in
/Users/paul/Dropbox/Electronics/Arduino/PJ PlatformIO Projects
that was causing the error.
I tried making a project under the default PlatformIO Projects folder and it compiled fine.
So I created a new folder just for my PlatformIO Artemis projects at
/Users/paul/Dropbox/Electronics/Arduino/PJ_PlatformIO_Artemis_Projects
and when I made a test Artemis project in there it compiled fine.
I then had an issue when trying to UPLOAD.
Looking for upload port...
Uploading .pio/build/SparkFun_Artemis_Module/firmware.bin
Artemis SVL Bootloader
Script version 1.7
Phase: Setup
Cleared startup blip
Failed to enter bootload phase
Phase: Setup
Phase: Setup
Target failed to enter bootload mode. Verify the right COM port is selected and that your board has the SVL bootloader.
