❯ pio run
Processing esp01_1m (platform: espressif8266; board: esp01_1m; framework: arduino)
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/esp01_1m.html
PLATFORM: Espressif 8266 2.6.2 > Espressif Generic ESP8266 ESP-01 1M
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
- framework-arduinoespressif8266 3.20704.0 (2.7.4)
- tool-esptool 1.413.0 (4.13)
- tool-esptoolpy 1.20800.0 (2.8.0)
- toolchain-xtensa 2.40802.200502 (4.8.2)
LibraryManager: Installing id=721 @ 3.1.6
[API] ConnectionError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v2/lib/info/721 (Caused by SSLError(SSLCertVerificationError("hostname 'api.registry.platformio.org' doesn't match either of '*.registry.nm1.platformio.org', 'registry.nm1.platformio.org'"))) (incremented retry: max=5, total=1)
[API] ConnectionError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v2/lib/info/721 (Caused by SSLError(SSLCertVerificationError("hostname 'api.registry.platformio.org' doesn't match either of '*.registry.nm1.platformio.org', 'registry.nm1.platformio.org'"))) (incremented retry: max=5, total=2)
[API] ConnectionError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v2/lib/info/721 (Caused by SSLError(SSLCertVerificationError("hostname 'api.registry.platformio.org' doesn't match either of '*.registry.nm1.platformio.org', 'registry.nm1.platformio.org'"))) (incremented retry: max=5, total=3)
[API] ConnectionError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v2/lib/info/721 (Caused by SSLError(SSLCertVerificationError("hostname 'api.registry.platformio.org' doesn't match either of '*.registry.nm1.platformio.org', 'registry.nm1.platformio.org'"))) (incremented retry: max=5, total=4)
[API] ConnectionError: HTTPSConnectionPool(host='api.registry.platformio.org', port=443): Max retries exceeded with url: /v2/lib/info/721 (Caused by SSLError(SSLCertVerificationError("hostname 'api.registry.platformio.org' doesn't match either of '*.registry.nm1.platformio.org', 'registry.nm1.platformio.org'"))) (incremented retry: max=5, total=5)
APIRequestError: [API] Could not connect to PlatformIO API Service. Please try later.:
So, yeah. Certificate error. Happens. Will be fixed at some point. That is not the problem.
The problem is that I can not get around it. I have this project completely local. No dependencies or anything needs to be downloaded. Everything is here. And yet pio not only exists to reach out to the internet on every pio run but there also seems to be no way around it. Any other build tool that I have seen has a “work local”, “offline”, “do not check” or anything flag that you can throw on the command line and then the build is fully local. If a dependency is missing, the build fails, but that is ok.
Right now, I am stuck with my project and I can’t seem to find a workaround short of blocking this hostname locally or shutting down my local wifi connection. That is a real problem; there should be a global flag to the pio command that will make it work only locally.
so all the libraries are here and they have the right versions. And I have them version locked, so I do not see any reason why pio is trying to connect to the servers in the first place.
ConnectionError: HTTPSConnectionPool(host='dl.registry.nm1.platformio.org', port=443): Max retries exceeded with url: /download/arkhipenko/library/TaskScheduler/3.1.6/TaskScheduler-3.1.6.tar.gz (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x7f4b985a4f10>: Failed to establish a new connection: [Errno -2] Name or service not known')):
otherwise I now see
SSLError: HTTPSConnectionPool(host='dl.registry.nm1.platformio.org', port=443): Max retries exceeded with url: /download/arkhipenko/library/TaskScheduler/3.1.6/TaskScheduler-3.1.6.tar.gz (Caused by SSLError(SSLCertVerificationError("hostname 'dl.registry.nm1.platformio.org' doesn't match either of '*.registry.platformio.org', 'registry.platformio.org'"))):
Yes, works now. Thank you for the quick reaction. I think it would still be useful to have a true “offline” mode in which pio never tries to establish a network connection.
PlatformIO does not require Internet connection. Everything works on your machine in offline mode. It goes to the PlatformIO Registry the only if there are no installed dependencies for your project (toolchains, libraries, etc.).
You can try to disconnect from Internet and experiment with your project.
I understand your comment, however it is not correct. The build process failed for me both with the failed certificate (because pio tried to update / validate / check something online and did not get “no route to host” but “connection refused” or an invalid certificate. Both problems caused pio to stop with an error instead of assuming that it is offline. This is a common fallacy with code that has an implicit “we still work if the internet is down” assumption. Because the internet can be down in many ways.
Which is why it would be useful to have a command line flag saying “do not try to do any attempt to connect to the network in any way”. Because it allows the user to enforce this offline mode (and there are good reasons to do so even if the network is available).
In my case, pio tried to connect to the internet (and failed) even though everything was available locally.
I did all the experimentation that you suggested (both voluntarily and involuntarily when the certificates were broken) and I feel that pio would benefit from such an “offline” flag.
I have the issue, I currently cannot run platfomrio and compile project due to certificate error;
$ pio platform run
Please wait while upgrading PlatformIO...
Error: HTTPSConnectionPool(host='api.registry.ns1.platformio.org', port=443): Max retries exceeded with url: /v3/packages?query=name%3A%22framework-arduino-avr%22+type%3A%22tool%22 (Caused by SSLError(CertificateError("hostname 'api.registry.ns1.platformio.org' doesn't match either of '*.platformio.org', 'platformio.org'",),))
Even switching off WiFi does not allow platformio to run
Error: You are not connected to the Internet.
PlatformIO needs the Internet connection to download dependent packages or to work with PlatformIO Account.
[sudo] password for fig:
I have both python 2 and python 3 installed. I’ve been running platformio on this machine for years, it worked fine until the last past platformio update. Admittedly I am running an older version of ubuntu 14.04 but I try to keep packages updated.
We don’t support Python 3.4. The minimum supported version is 3.5+.
2.7.9 is the minimum supported version for Python 2. Python 2 is already deprecated. We plan to drop support for it as well soon.
Is it possible to upgrade Python at your machine? PlatformIO Core 4.0 used HTTP instead of HTTPS. This is insecure. This is why it worked for you. Now, everything works over HTTPS. Python 2.7.6 has broken SSL support.
I tried to upload my blink code by esp8266 on win10.I meet the same error.
Error: HTTPSConnectionPool(host='api.registry.ns1.platformio.org', port=443): Max retries exceeded with url: /v3/packages/platformio/tool/tool-mkspiffs (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:1123)')))
The platformIO is installed from vscode.
My python env is python 3.9.2
$ C:\Users\60292\.platformio\penv\Scripts\python.exe --version
Python 3.9.2
here is the output after typing pio system info
$ pio system info
PlatformIO Core 5.2.0
Python 3.9.2-final.0
System Type windows_amd64
Platform Windows-10
File System Encoding utf-8
Locale Encoding cp936
PlatformIO Core Directory C:\Users\60292\.platformio
PlatformIO Core Executable C:\Users\60292\.platformio\penv\Scripts\platformio.exe
Python Executable C:\Users\60292\.platformio\penv\Scripts\python.exe
Global Libraries 0
Development Platforms 1
Tools & Toolchains 6
Likely some antivirus or SSL proxy is interfering with the connection – not good.
When you open https://api.registry.ns1.platformio.org/ in a browser, what certificate do you see? (Usually you can click on the padlock in the URL bar to get to the certificate info)
Well that it may be valid for the local computer / browser makes sense, the important part is which certificate chain it is. There should a button to get to the certificate details showing the chain.
