Public key parameters is 05 00
(I can’t upload more than one image at the same time because of the limit of editor)
Are you using an SSL proxy to get to the outside internet? Have you set it up in PlatformIO IDE for VSCode — PlatformIO latest documentation?
I have solved the problem rudely……Thanks for your explain,I find the problem in my proxy. So I closed the clash app,a proxy helped me cross chinese gateway, directly.
I have tried to solved this problem by unchecking vscode’s proxy ssl checkbox. But it failed.
So thanks for your help.
遇到一样的问题了,也是开了小火箭。谢谢解答。
i have same question like you. But the downloading speed is so slow if i closed the clash. May I have a way that can download the uploading tools through proxy?
