Indeed, this is currently incompilable. Downloading the Sermoon-D1 Source code.zip file, extracting it and using pio run fails with errors related to wanting to use libmaple but the STM32 core being used actually. The Marlin version there is outdated.
Sadly, due to older versions of Marlin pointing its library and platform dependencies directly at repos’s master branches (which continously move…) or not pinning a version at all, older Marlin firmwares have become basically incompilable without fixing up all the used versions to the ones which they were at the time of the Marlin release.
A good point of reference for the firmware you’re working is the versions seen in Marlin/platformio.ini at 2.0.6.1 · MarlinFirmware/Marlin · GitHub, but for some libs like the TMCStepper one it’s not an exact match.
I found that with the platformio.ini (and no source code changes)
# Marlin Firmware
# PlatformIO Configuration File
# For detailed documentation with EXAMPLES:
# http://docs.platformio.org/en/latest/projectconf.html
# Automatic targets - enable auto-uploading
# targets = upload
# By default platformio build will abort after 5 errors.
# Remove '-fmax-errors=5' from build_flags below to see all.
[platformio]
src_dir = Marlin
boards_dir = buildroot/share/PlatformIO/boards
default_envs = creality
[common]
default_src_filter = +<src/*> -<src/config> -<src/HAL> +<src/HAL/shared>
extra_scripts = pre:buildroot/share/PlatformIO/scripts/common-cxxflags.py
build_flags = -fmax-errors=5 -g -D__MARLIN_FIRMWARE__ -fmerge-all-constants
U8glib-HAL=https://github.com/MarlinFirmware/U8glib-HAL/archive/bugfix.zip
LiquidCrystal@1.3.4
TMCStepper@0.6.1
Adafruit NeoPixel@1.2.5
Adafruit_MAX31865=Adafruit MAX31865 library@~1.1.0
LiquidTWI2=https://github.com/lincomatic/LiquidTWI2/archive/master.zip
Arduino-L6470=https://github.com/ameyer/Arduino-L6470/archive/dev.zip
SailfishLCD=https://github.com/mikeshub/SailfishLCD/archive/master.zip
SailfishRGB_LED=https://github.com/mikeshub/SailfishRGB_LED/archive/master.zip
SlowSoftI2CMaster=https://github.com/mikeshub/SlowSoftI2CMaster/archive/master.zip
# Globally defined properties
# inherited by all environments
[env]
build_flags = ${common.build_flags}
lib_deps = ${common.lib_deps}
# Unique Core Architectures #
# Add a new "env" below if no #
# entry has values suitable to #
# build for a given board. #
# ATmega2560
[env:megaatmega2560]
board = megaatmega2560
board_build.f_cpu = 16000000L
TMC26XStepper=https://github.com/trinamic/TMC26XStepper/archive/master.zip
src_filter = ${common.default_src_filter} +<src/HAL/HAL_AVR>
monitor_speed = 250000
# ATmega1280
[env:megaatmega1280]
extends = env:megaatmega2560
board = megaatmega1280
# RAMBo
[env:rambo]
board = reprap_rambo
# FYSETC F6 V1.3
[env:fysetc_f6_13]
board = fysetc_f6_13
# Sanguinololu (ATmega644p)
[env:sanguino_atmega644p]
board = sanguino_atmega644p
# Sanguinololu (ATmega1284p)
[env:sanguino_atmega1284p]
extends = env:sanguino_atmega644p
board = sanguino_atmega1284p
# Melzi and clones (ATmega1284p)
[env:melzi]
extends = env:sanguino_atmega1284p
lib_ignore = TMCStepper
upload_speed = 57600
# Melzi and clones (Optiboot bootloader)
[env:melzi_optiboot]
extends = env:melzi
upload_speed = 115200
# AT90USB1286 boards using CDC bootloader
# - BRAINWAVE
# - BRAINWAVE_PRO
# - SAV_MKI
# - TEENSYLU
[env:at90usb1286_cdc]
platform = teensy
board = at90usb1286
# AT90USB1286 boards using DFU bootloader
# - PrintrBoard
# - PrintrBoard Rev.F
# - ? 5DPRINT ?
[env:at90usb1286_dfu]
extends = env:at90usb1286_cdc
# Due (Atmel SAM3X8E ARM Cortex-M3)
# - RAMPS4DUE
# - RADDS
[env:DUE]
platform = atmelsam
board = due
src_filter = ${common.default_src_filter} +<src/HAL/HAL_DUE>
[env:DUE_USB]
extends = env:DUE
board = dueUSB
[env:DUE_debug]
# Used when WATCHDOG_RESET_MANUAL is enabled
extends = env:DUE
-funwind-tables
-mpoke-function-name
# NXP LPC176x ARM Cortex-M3
[env:LPC1768]
platform = https://github.com/p3p/pio-nxplpc-arduino-lpc176x/archive/0.1.2.zip
board = nxp_lpc1768
build_flags = -DU8G_HAL_LINKS -IMarlin/src/HAL/HAL_LPC1768/include -IMarlin/src/HAL/HAL_LPC1768/u8g ${common.build_flags}
# debug options for backtrace
# -funwind-tables
# -mpoke-function-name
lib_ldf_mode = off
lib_compat_mode = strict
extra_scripts = Marlin/src/HAL/HAL_LPC1768/upload_extra_script.py
src_filter = ${common.default_src_filter} +<src/HAL/HAL_LPC1768>
lib_deps = Servo
LiquidCrystal
TMCStepper@>=0.6.1,<1.0.0
Adafruit NeoPixel=https://github.com/p3p/Adafruit_NeoPixel/archive/release.zip
[env:LPC1769]
extends = env:LPC1768
board = nxp_lpc1769
# STM32F1 base
[env:STM32F1_base]
platform = ststm32@~12.1
board_build.core = maple
platform_packages = framework-arduinoststm32-maple@2.10000.200103
build_flags = !python Marlin/src/HAL/HAL_STM32F1/build_flags.py
${common.build_flags} -std=gnu++14
build_unflags = -std=gnu++11
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32F1>
lib_ignore = Adafruit NeoPixel, SPI
# STM32F103RC
[env:STM32F103RC_base]
extends = env:STM32F1_base
board = genericSTM32F103RC
platform_packages = tool-stm32duino
SoftwareSerialM=https://github.com/FYSETC/SoftwareSerialM/archive/master.zip
# STM32F103RC_fysetc
[env:STM32F103RC_fysetc]
extends = env:STM32F103RC_base
#board_build.core = maple
extra_scripts = buildroot/share/PlatformIO/scripts/STM32F103RC_fysetc.py
${common.build_flags} -std=gnu++14 -DDEBUG_LEVEL=0 -DHAVE_SW_SERIAL
lib_ldf_mode = chain
debug_tool = stlink
upload_protocol = serial
# BigTree SKR Mini V1.1 / SKR mini E3 / SKR E3 DIP (STM32F103RCT6 ARM Cortex-M3)
# STM32F103RC_bigtree ............. RCT6 with 256K
# STM32F103RC_bigtree_USB ......... RCT6 with 256K (USB)
# STM32F103RC_bigtree_512K ........ RCT6 with 512K
# STM32F103RC_bigtree_512K_USB .... RCT6 with 512K (USB)
[env:STM32F103RC_bigtree]
extra_scripts = buildroot/share/PlatformIO/scripts/STM32F103RC_SKR_MINI.py
${common.build_flags} -DDEBUG_LEVEL=0 -std=gnu++14 -DHAVE_SW_SERIAL -DSS_TIMER=4
[env:STM32F103RC_bigtree_USB]
extends = env:STM32F103RC_bigtree
${common.build_flags} -DDEBUG_LEVEL=0 -std=gnu++14 -DHAVE_SW_SERIAL -DSS_TIMER=4 -DUSE_USB_COMPOSITE
[env:STM32F103RC_bigtree_512K]
board_upload.maximum_size=524288
${common.build_flags} -DDEBUG_LEVEL=0 -std=gnu++14 -DHAVE_SW_SERIAL -DSS_TIMER=4 -DSTM32_FLASH_SIZE=512
[env:STM32F103RC_bigtree_512K_USB]
extends = env:STM32F103RC_bigtree_512K
${common.build_flags} -DDEBUG_LEVEL=0 -std=gnu++14 -DHAVE_SW_SERIAL -DSS_TIMER=4 -DSTM32_FLASH_SIZE=512 -DUSE_USB_COMPOSITE
# STM32F103RE_base
[env:STM32F103RE_base]
board = genericSTM32F103RE
# STM32F103RE
[env:STM32F103RE]
extends = env:STM32F103RE_base
# STM32F103RE_bigtree ............. RET6
# STM32F103RE_bigtree_USB ......... RET6 (USB)
[env:STM32F103RE_bigtree]
extra_scripts = buildroot/share/PlatformIO/scripts/STM32F103RE_SKR_E3_DIP.py
debug_tool = stlink
upload_protocol = stlink
[env:STM32F103RE_bigtree_USB]
extends = env:STM32F103RE_bigtree
# STM32F4 with STM32GENERIC
[env:STM32F4]
platform = ststm32
board = disco_f407vg
build_flags = ${common.build_flags} -DUSE_STM32GENERIC -DSTM32GENERIC -DSTM32F4 -DMENU_USB_SERIAL -DMENU_SERIAL=SerialUSB -DHAL_IWDG_MODULE_ENABLED
lib_ignore = Adafruit NeoPixel, TMCStepper
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32_F4_F7> -<src/HAL/HAL_STM32_F4_F7/STM32F7>
# STM32F7 with STM32GENERIC
[env:STM32F7]
platform = ststm32
board = remram_v1
build_flags = ${common.build_flags} -DUSE_STM32GENERIC -DSTM32GENERIC -DSTM32F7 -DMENU_USB_SERIAL -DMENU_SERIAL=SerialUSB -DHAL_IWDG_MODULE_ENABLED
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32_F4_F7> -<src/HAL/HAL_STM32_F4_F7/STM32F4>
# ARMED (STM32)
[env:ARMED]
platform = ststm32
board = armed_v1
-DUSBCON -DUSBD_VID=0x0483 '-DUSB_MANUFACTURER="Unknown"' '-DUSB_PRODUCT="ARMED_V1"' -DUSBD_USE_CDC
-O2 -ffreestanding -fsigned-char -fno-move-loop-invariants -fno-strict-aliasing -std=gnu11 -std=gnu++11
-IMarlin/src/HAL/HAL_STM32
lib_ignore = Adafruit NeoPixel, SoftwareSerial
src_filter = ${common.default_src_filter} +<src/HAL/HAL_STM32>
# Longer 3D board in Alfawise U20 (STM32F103VET6)
[env:STM32F103VE_longer]
board = genericSTM32F103VE
extra_scripts = buildroot/share/PlatformIO/scripts/STM32F103VE_longer.py
${common.build_flags} -std=gnu++14 -USERIAL_USB
-DSTM32F1xx -DU20 -DTS_V12
build_unflags = -std=gnu++11 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DERROR_LED_PORT=GPIOE -DERROR_LED_PIN=6
lib_ignore = Adafruit NeoPixel, LiquidTWI2, SPI
# MKS Robin (STM32F103ZET6)
[env:mks_robin]
board = genericSTM32F103ZE
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin.py
${common.build_flags} -std=gnu++14 -DSTM32_XL_DENSITY
# MKS Robin Lite/Lite2 (STM32F103RCT6)
[env:mks_robin_lite]
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin_lite.py
# MKS Robin Mini (STM32F103VET6)
[env:mks_robin_mini]
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin_mini.py
# MKS Robin Nano (STM32F103VET6)
[env:mks_robin_nano]
extra_scripts = buildroot/share/PlatformIO/scripts/mks_robin_nano.py
# JGAurora A5S A1 (STM32F103ZET6)
[env:jgaurora_a5s_a1]
extra_scripts = buildroot/share/PlatformIO/scripts/jgaurora_a5s_a1_with_bootloader.py
${common.build_flags} -DSTM32F1xx -std=gnu++14 -DSTM32_XL_DENSITY
# Malyan M200 (STM32F103CB)
[env:STM32F103CB_malyan]
platform = ststm32
board = malyanM200
build_flags = !python Marlin/src/HAL/HAL_STM32F1/build_flags.py -DMCU_STM32F103CB -D __STM32F1__=1 -std=c++1y -D MOTHERBOARD="BOARD_MALYAN_M200" -DSERIAL_USB -ffunction-sections -fdata-sections -Wl,--gc-sections
-DDEBUG_LEVEL=0 -D__MARLIN_FIRMWARE__
lib_ignore = Adafruit NeoPixel, LiquidCrystal, LiquidTWI2, TMCStepper, U8glib-HAL, SPI
# Chitu boards like Tronxy X5s (STM32F103ZET6)
[env:chitu_f103]
extra_scripts = buildroot/share/PlatformIO/scripts/chitu_crypt.py
build_unflags = -std=gnu++11 -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG= -DERROR_LED_PORT=GPIOE -DERROR_LED_PIN=6
# Creality (STM32F103RET6)
[env:creality]
extra_scripts = buildroot/share/PlatformIO/scripts/creality.py
debug_tool = jlink
upload_protocol = jlink
# STM32 HAL environments
[env:STM32_hal]
platform = ststm32
# FYSETC S6 (STM32F446VET6 ARM Cortex-M4)
[env:FYSETC_S6]
extends = env:STM32_hal
board = fysetc_s6
extra_scripts = buildroot/share/PlatformIO/scripts/fysetc_STM32S6.py
-DTARGET_STM32F4 -std=gnu++14
-DVECT_TAB_OFFSET=0x10000
-DUSBCON -DUSBD_USE_CDC -DHAL_PCD_MODULE_ENABLED -DUSBD_VID=0x0483 '-DUSB_PRODUCT="FYSETC_S6"'
lib_ignore = Arduino-L6470
debug_tool = stlink
#upload_protocol = stlink
# STM32F407VET6 with RAMPS-like shield
# 'Black' STM32F407VET6 board - http://wiki.stm32duino.com/index.php?title=STM32F407
# Shield - https://github.com/jmz52/Hardware
[env:STM32F407VE_black]
platform_packages = framework-arduinoststm32@>=3.10700.191028
board = blackSTM32F407VET6
extra_scripts = pre:buildroot/share/PlatformIO/scripts/generic_create_variant.py
-DTARGET_STM32F4 -DARDUINO_BLACK_F407VE
-DUSBCON -DUSBD_USE_CDC -DUSBD_VID=0x0483 -DUSB_PRODUCT=\"BLACK_F407VE\"
lib_ignore = Adafruit NeoPixel, TMCStepper, SailfishLCD, SailfishRGB_LED, SlowSoftI2CMaster, SoftwareSerial
# Bigtreetech SKR Pro (STM32F407ZGT6 ARM Cortex-M4)
[env:BIGTREE_SKR_PRO]
board = BigTree_SKR_Pro
-DUSBCON -DUSBD_USE_CDC -DUSBD_VID=0x0483 -DUSB_PRODUCT=\"STM32F407ZG\"
-DTARGET_STM32F4 -DSTM32F407_5ZX -DVECT_TAB_OFFSET=0x8000
-DHAVE_HWSERIAL6
LiquidCrystal
TMCStepper@>=0.5.2,<1.0.0
Adafruit NeoPixel
lib_ignore = SoftwareSerial, SoftwareSerialM
# Bigtreetech SKR BTT002 (STM32F407VET6 ARM Cortex-M4)
[env:BIGTREE_BTT002]
platform = ststm32@5.6.0
board = BigTree_Btt002
-DUSBCON -DUSBD_USE_CDC -DUSBD_VID=0x0483 -DUSB_PRODUCT=\"STM32F407VE\"
-DTARGET_STM32F4 -DSTM32F407_5VX -DVECT_TAB_OFFSET=0x8000
-DHAVE_HWSERIAL2
-DHAVE_HWSERIAL3
-DPIN_SERIAL2_RX=PD_6
-DPIN_SERIAL2_TX=PD_5
lib_ignore = Adafruit NeoPixel, SailfishLCD, SailfishRGB_LED, SlowSoftI2CMaster
# Teensy 3.1 / 3.2 (ARM Cortex-M4)
[env:teensy31]
platform = teensy
board = teensy31
src_filter = ${common.default_src_filter} +<src/HAL/HAL_TEENSY31_32>
# Teensy 3.5 / 3.6 (ARM Cortex-M4)
[env:teensy35]
extends = env:teensy31
board = teensy35
src_filter = ${common.default_src_filter} +<src/HAL/HAL_TEENSY35_36>
# Espressif ESP32
[env:esp32]
upload_port = /dev/ttyUSB0
AsyncTCP=https://github.com/me-no-dev/AsyncTCP/archive/master.zip
ESPAsyncWebServer=https://github.com/me-no-dev/ESPAsyncWebServer/archive/master.zip
lib_ignore = LiquidCrystal, LiquidTWI2, SailfishLCD, SailfishRGB_LED
src_filter = ${common.default_src_filter} +<src/HAL/HAL_ESP32>
# Native
# No supported Arduino libraries, base Marlin only
[env:linux_native]
platform = native
framework =
build_flags = -D__PLAT_LINUX__ -std=gnu++17 -ggdb -g -lrt -lpthread -D__MARLIN_FIRMWARE__ -Wno-expansion-to-defined
src_build_flags = -Wall -IMarlin/src/HAL/HAL_LINUX/include
build_unflags = -Wall
lib_ldf_mode = off
extra_scripts =
src_filter = ${common.default_src_filter} +<src/HAL/HAL_LINUX>
# Adafruit Grand Central M4 (Atmel SAMD51P20A ARM Cortex-M4)
[env:SAMD51_grandcentral_m4]
platform = atmelsam
board = adafruit_grandcentral_m4
build_flags = ${common.build_flags} -std=gnu++17
extra_scripts = ${common.extra_scripts}
src_filter = ${common.default_src_filter} +<src/HAL/HAL_SAMD51>
debug_tool = jlink
# Just print the dependency tree
[env:include_tree]
build_flags = -c -H -std=gnu++11 -Wall -Os -D__MARLIN_FIRMWARE__
src_filter = +<src/Marlin.cpp>
The firmware compiles just fine. Don’t forget to remove the .pio folder before compilation to get a clean compile.
Linking .pio\build\creality\firmware.elf
Checking size .pio\build\creality\firmware.elf
RAM: [== ] 22.9% (used 14984 bytes from 65536 bytes)
Flash: [=== ] 31.8% (used 166492 bytes from 524288 bytes)
Building .pio\build\creality\firmware.bin
============== [SUCCESS] Took 41.98 seconds ==============
Specifically, the critical changes were
TMCStepper@0.6.1
and
[env:STM32F1_base]
