Basically, following the docs leads to an permission error during installation of platformio
Short form:
$ pip2 install -U platformio
OSError: [Errno 13] Permission denied: '/usr/lib/python2.7/dist-packages/chardet/euckrprober.py'
Any ideas on what’s going on?
gitlab-ci.yml
image: python:2
variables:
GIT_SUBMODULE_STRATEGY: recursive
stages:
- build
before_script:
- pip2 install -U platformio
job:
stage:
build
script:
- make
artifacts:
paths:
- .pioenvs/featheresp8266/firmware.elf
tags:
- staging
job output
Collecting platformio
Using cached https://files.pythonhosted.org/packages/d2/4a/0a69838890fdabe4603fdb3c1bc6c77e8f20e8b7391a21643505214a907c/platformio-3.5.2-py27-none-any.whl
Requirement already up-to-date: lockfile<0.13,>=0.9.1 in /usr/local/lib/python2.7/dist-packages (from platformio)
Requirement already up-to-date: colorama in /usr/local/lib/python2.7/dist-packages (from platformio)
Requirement already up-to-date: semantic-version<3,>=2.5.0 in /usr/local/lib/python2.7/dist-packages (from platformio)
Requirement already up-to-date: bottle<0.13 in /usr/local/lib/python2.7/dist-packages (from platformio)
Collecting requests<3,>=2.4.0 (from platformio)
Using cached https://files.pythonhosted.org/packages/49/df/50aa1999ab9bde74656c2919d9c0c085fd2b3775fd3eca826012bef76d8c/requests-2.18.4-py2.py3-none-any.whl
Collecting click<6,>=5 (from platformio)
Using cached https://files.pythonhosted.org/packages/8f/98/14966b6d772fd5fba1eb3bb34a62a7f736d609572493397cdc5715c14514/click-5.1-py2.py3-none-any.whl
Collecting pyserial!=3.3,<4,>=3 (from platformio)
Using cached https://files.pythonhosted.org/packages/0d/e4/2a744dd9e3be04a0c0907414e2a01a7c88bb3915cbe3c8cc06e209f59c30/pyserial-3.4-py2.py3-none-any.whl
Collecting certifi>=2017.4.17 (from requests<3,>=2.4.0->platformio)
Using cached https://files.pythonhosted.org/packages/7c/e6/92ad559b7192d846975fc916b65f667c7b8c3a32bea7372340bfe9a15fa5/certifi-2018.4.16-py2.py3-none-any.whl
Collecting chardet<3.1.0,>=3.0.2 (from requests<3,>=2.4.0->platformio)
Using cached https://files.pythonhosted.org/packages/bc/a9/01ffebfb562e4274b6487b4bb1ddec7ca55ec7510b22e4c51f14098443b8/chardet-3.0.4-py2.py3-none-any.whl
Collecting idna<2.7,>=2.5 (from requests<3,>=2.4.0->platformio)
Using cached https://files.pythonhosted.org/packages/27/cc/6dd9a3869f15c2edfab863b992838277279ce92663d334df9ecf5106f5c6/idna-2.6-py2.py3-none-any.whl
Collecting urllib3<1.23,>=1.21.1 (from requests<3,>=2.4.0->platformio)
Using cached https://files.pythonhosted.org/packages/63/cb/6965947c13a94236f6d4b8223e21beb4d576dc72e8130bd7880f600839b8/urllib3-1.22-py2.py3-none-any.whl
Installing collected packages: certifi, chardet, idna, urllib3, requests, click, pyserial, platformio
Found existing installation: chardet 2.3.0
Uninstalling chardet-2.3.0:
Exception:
File "/usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg/pip/basecommand.py", line 215, in main
status = self.run(options, args)
File "/usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg/pip/commands/install.py", line 342, in run
prefix=options.prefix_path,
File "/usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg/pip/req/req_set.py", line 778, in install
requirement.uninstall(auto_confirm=True)
File "/usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg/pip/req/req_install.py", line 754, in uninstall
paths_to_remove.remove(auto_confirm)
File "/usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg/pip/req/req_uninstall.py", line 115, in remove
renames(path, new_path)
File "/usr/local/lib/python2.7/dist-packages/pip-9.0.1-py2.7.egg/pip/utils/__init__.py", line 267, in renames
shutil.move(old, new)
File "/usr/lib/python2.7/shutil.py", line 300, in move
rmtree(src)
File "/usr/lib/python2.7/shutil.py", line 252, in rmtree
onerror(os.remove, fullname, sys.exc_info())
File "/usr/lib/python2.7/shutil.py", line 250, in rmtree
os.remove(fullname)
You are using pip version 9.0.1, however version 10.0.1 is available.
You should consider upgrading via the 'pip install --upgrade pip' command.
ERROR: Job failed: exit status 1
