PlatformIO on Cursor IDE
I’m using Cursor IDE and want to install PlatformIO. Found it in extensions and installed it. Clicking on it starts “Initializing PlatformIO Core…” and nothing happens thereafter. Do I need any other dependencies to get this going or am I missing anything else?
I think it may run for some time in the background if it’s the first time install. I certainly ran PlatformIO in Cursor.
Ok, I tried again and don’t see any activity in the output tab for the last 30 mins. So I’m not sure this is doing anything. I remember having it installed on VSC a few months ago without any issues.
I’m on the latest Cursor version v2.6.22
Same problem…VSC works properly but not Cursor IDE :frowning:
See Platformio in Cursor. Publication to OpenVSX
Try Open VSX Registry
Interesting observation:
This Thread is #1 Google Result for “platformio” Search
(in Mexico and Canada)
Also Cursor → Extensions (openvsix) has three forks of PlatformIO
There are currently three forks that shows up in openvsix in Cursor IDE:
It’s still possible to install the main PlatformIO in Cursor but you need to make some (relatively non-intuitive) manual edits. Especially if you’re using WSL in Cursor.
Now that said, there seems to be github activity to improve the main PlatformIO for an easier out-of-box solution to obsolete those forks.
So hopefully the situation resolves itself (eventually) as useful features (ability to use clang, etc, ability to choose a different intellisense engine, etc) gets ported over that improves compatibility with multiple VSCode forks.
Being that said, the situation is so intense-demand that Google #1 search result for “platformio” is this thread.
Uxe pioarduino VSC extension
