If anyone is interested:
Testing LoRaWAN
Great stuff! This would make an excellent addition to the existing platform-atmelsam which only has one Atmel SAM-R21 chip support. And the, CMSIS, ASF and Blink framework additions are also great.
@ivankravets and/or @valeros can check if integration will be done.
my opinion is ⦠do not mix MCU and SiP chips
there are specific things ⦠will complicating the normal platform
btw: SiP is SAML21+SX1276
I have tested this platform with a RAK4260 board with minor changes (thanks Georgi) successfully sending multichannel LoRaWAN messages both with abp an ottaa.
Adding Arduino framework to these chips is a great step forward.
First Great job @wizio
Hello @mromani
to join otaa have you changed anything other then setting the devEUI, appEUI, appKey?
Hi @mromani, could you share what changes you did?
I can identify I need to add a new board definition (json) and a variant, at most.
Is there anything else you added? any chances to share the code?
Regards
Hi @wizio,
I am working in SAMR34 development board . with platformIO with your firmware. I have used Arduino Platform. for SAMR34 Xplained PRO DM320111 (development board) Works great . and I have built the board with ATSAMR34J18 soc and upload the hex file of the platformio code. using J_LINK lite. I doesnāt work.
The problem I found here is BARMETAL code asf_blink hex is work fine in the custom board . but LED blink Arduino code for this board in not working when it is upload to custom board . But The same LED BLINK code is working in the development broad .
I not have j-link and standalone module now ( home office ) to find what is wrong
Does anyone have worked on custom SAMR34 board & Use IDE as platform IO ?
The first post in this topic is a link to a custom platform with SAMR34 support. Does that not work?
Yes, It works fine , Also developed whole firmware in platform IO.
Now hex donāt work in custom board.
Or can you please suggest how can configure ATMEL ICE with platform IO , so I can load directly and test.
Hello, I hope I“m on the right topic.
I“m working with the BastWan board that has a RAK4260, based on the SAMR34. While I do have an ATMEL ICE programmer and could program the SAMR34 correctly in PlatformIO, but I would like to keep the USB bootloader installed and program the SAMR34 via Bossac.
When I using the ElectronicCats BastWAN in the Arduino IDE, I noticed that the Arduino IDE is using Bossac to program the SAMR34.
Blockquote
Documents\ArduinoData\packages\electroniccats\tools\bossac\1.0.0-electroniccats-1/bossac.exe -i -d --port=COM21 -U true -i -e -w -v
Blockquote
When I compiled the same code in PlatformIO and manually used Bossac to program the SAMR34 the code didn“t correctly run. Is my code compile differently in Arduino IDE than in PlatformIO?
Site to find the USB bootloader
Serial.println(ātestā);
delay(1000);
The article youāre refering to seems to be using the Arduino packages from this page: GitHub - ElectronicCats/Arduino_Boards_Index: Electronic Cats Package Lists for the Arduino Board Manager
While this posts talks about a custom platform which uses this core implementation: framework-sam-lora/arduino at master Ā· Wiz-IO/framework-sam-lora Ā· GitHub
And they seem to be very different, e.g. the above doesnāt even have the bastwan variant youāre looking for.
Iāve unpacked the core given in the first link at GitHub - maxgerhardt/pio-electroniccats-samd: PlatformIO package for Electroniccats SAMD and R core and added the PlatformIO specific files to it.
Iām assuming youāre selecting āBastWANā board which maps to this variant.
Can you please try and clone the following project: GitHub - maxgerhardt/pio-bastwan-test and see if you can build and upload it?
Sadly I donāt have the board to test, so Iām flying blind here. For me, it at least compiles, using the modified Arduino core and Atmel CMSIS headers.
Checking size .pio\build\bastwan\firmware.elf
RAM: [= ] 5.2% (used 2136 bytes from 40960 bytes)
Flash: [ ] 3.9% (used 9984 bytes from 253952 bytes)
================== [SUCCESS] Took 3.65 seconds ====================
Hi maxgerhardt,
I compiled the project that you put on Gitlab and was able to compile it. But I was not able to upload it via PlatformIO.
Then I tried to upload the firmware.bin file via bossac via the following line in Powershell:
.\bossac.exe -i -d --port=COM21 -U true -i -e -w -v ./firmware.bin -R
And the program started to run, thanks for the help, I didn“t add the include.
After I did have success with Bossac, I tried to upload via PlatformIO again, but without success. I did notice that the COM port that was 20, changed again to COM21 (the bootloader com). Can it be that PlatformIO uses a different Bossac configuration?
It uses a different bossac package, yes.
There could be three problem sources:
platformio.ini
that also redirects tool-bossac
from here
I have been continuing to look into Bossa, it looks like Electronicscats uses a new version of Bossa.
āBasic Open Source SAM-BA Application (BOSSA) Version 1.7.0-mattairtech-3ā
The old version shows the following error:
āUnsupported processorā
.\bossac_or.exe -i -d -U true -i -e -w -v ./firmware.bin -R
Trying to connect on COM21
Set binary mode
readWord(addr=0)=0x20002df0
readWord(addr=0xe000ed00)=0x410cc601
readWord(addr=0x41002018)=0x10810228
version()=v1.1 [Arduino:XYZ] Jul 13 2020 08:36:04
chipId=0x10810028
Send auto-baud
Set binary mode
chipId=0x10810028
Auto scan for device failed
Try specifying a serial port with the ā-pā option
.\bossac.exe -i -d -U true -i -e -w -v ./firmware.bin -R
Set binary mode
chipId=0x10810028
Connected at 921600 baud
Device found on COM21
Atmel SMART device 0x10810028 found
write(addr=0x20004000,size=0x34)
writeWord(addr=0x20004030,value=0x10)
writeWord(addr=0x20004020,value=0x20008000)
Device : ATSAMR34J18
Chip ID : 10810028
Version : v1.1 [Arduino:XYZ] Jul 13 2020 08:36:04
Address : 8192
Pages : 3968
ā¦
ā¦
Upload is still possible
I copied the newer Bossac version to the tool-bossac
folder in PlatfromIO and now was able to upload my code to the SAMR34. The code did run correctly. Thanks, Maxgerhardt.
Great to hear. Iāll file a feature request in GitHub - platformio/platform-atmelsam: Atmel SAM: development platform for PlatformIO regarding this ElectronicCats Arduino core so that official support may come eventually
Hm per updated platformio.ini
that uses the platform_packages = tool-bossac@..
directive that shouldnāt be necessary, but your way also works.
