For starters, neither the Arduino
library (folder) or CurieBLE
library (folder) should be present in the global .platformio\libs
folder.
Maybe this will make it clearer. Not all #includes
/ libraries are libraries which you (the end user) should be managing, or be having anything to do with. Nor should be putting in any folders manually. Framework provided libraries are just that, libraries provided by the framework (e.g. Arduino), and all you do is do an #include
when you want to use them. That’s it. Another example would be the libraries provided by the ESP8266Arduino framework… you don’t install/manage libraries like ESP8266WiFi.h, FS.h, ESP8266mDNS.h, ArduinoOTA.h, Ticker.h
, etc… you just include them and they are there.
So, for libraries that are provided by the framework, if they are not found, something is misconfigured in your platformio.ini
. Also, since they are provided by the framework (arduino
in this case), there is also no need to use lib_deps
to instruct platformio that it needs to download them. Finally, there should only be one lib_deps =
reference in your platformio.ini
. If you need to list multiple libraries, list them one after the other like this
RF24
RF24Network
If you don’t have framework = arduino
, that’s your problem.
Given that CurieBLE is specific to the Genuino101, I created a new project using your code, and used the following platformio.ini
[env:genuino101]
platform = intel_arc32
board = genuino101
It failed to compile …
… because the function was used before it was declared. Adding the declaration at the top …
… and it compiles just fine. And as you can see from the above screenshot, no IntelliSense / red squiggle issues.
