For a project of mine, I’ve set up a separate library (xxxx-lib), which I reference into xxxx-* projects.
For local development, reference is made this way in projects using this lib
../xxxx-lib/
The lib itself depends on external libs, mentionned in the lib manifest, for example
"dependencies": [
"owner": "ottowinter",
"name": "ESPAsyncWebServer-esphome",
"platforms": "espressif32",
"version": "^3.0.0"
However, when trying to build a xxxx-* project (it’s not mentinning the lib’s own dependency in its own platformio.ini lib_deps),
platformio run --environment ser
I get the following error :
.pio/libdeps/ser/xxxx-lib/webserver.cpp:7:10: fatal error: ESPAsyncWebServer.h: No such file or directory
* Looking for ESPAsyncWebServer.h dependency? Check our library registry!
* CLI > platformio lib search "header:ESPAsyncWebServer.h"
* Web > https://registry.platformio.org/search?q=header:ESPAsyncWebServer.h
#include <ESPAsyncWebServer.h>
compilation terminated.
How can we describe lib’s dependencies for a lib (the way we describe it in platformio.ini for a user project)? i thought the lib manifest was the way to go ?
Any idea?
Thank you !
