hello,
I made a project using the ledc functions from esp-idf to control LEDs. When i compile it in VSCode using the Espressif-IDF extension it works, but when i compile the same code using the PlatformIO extension it won’t compile because some parts of ledc.h are missing in the PlatformIO version vs the Espressif-IDF version, one example:
Compiling .pio/build/nodemcu-32s/src/main.o
src/main.c: In function 'app_main':
src/main.c:110:5: error: unknown type name 'ledc_cbs_t'; did you mean 'ledc_mode_t'?
ledc_cbs_t callbacks = {
When i search for the ledc_cbs_t i find a reference to it in the Espressif-IDF version of ledc.h but not in the PlatformIO version. I also notice on top of those files the copyright of the PlatformIO version of ledc.h goes from 2015-2019 and the Espressif-IDF version goes from 2015-2022.
Info about my setup
Debian Bullseye
VSCode 1.65.2
Espressif IDF extension V1.4.0
PlatformIO IDE extension V2.4.3 Core 5.2.5 Home 3.4.1
PlatformIO Platform: Espressif 3.5.0 (with ESP-IDF v4.3.2)
What could be the problem, any help is apreciated.
Thank you
