Hi PIO community,
I’m trying to build an example from a new FTP library I’m testing and unfortunately I’m getting the build error shown below:
In file included from C:/Users/nitin/Documents/PlatformIO/Projects/240302-225346-featheresp32/src/Arduino_esp32_SD.ino:14:
C:/Users/nitin/Documents/Arduino/libraries/EmotiBit_SimpleFTPServer/FtpServer.h:206:11: fatal error: WiFi.h: No such file or directory
The example I’m trying to run can be found here: EmotiBit_SimpleFTPServer/examples/Arduino_esp32_SD/Arduino_esp32_SD.ino at master · EmotiBit/EmotiBit_SimpleFTPServer · GitHub. The library is placed in my Documents/Arduino/libraries
to support Arduino as well as PIO.
The one modification made to the above example, was to comment out the following includes,
[line 10] //#include <WiFi.h>
[line 11] //#include "SD.h"
because
- they are included by
FtpServer.h
downstream. (which is what is breaking) - Im using this library as a part of a bigger project that supports more than 1 MCU so I want the library to selectively include the dependencies (instead of me defining them)
The library is located in my/Documents/Arduino/libraries
. Also, it compiles fine using Arduino IDE.
I have tried to compile this with 2 versions of the platformio.ini file.
File that does not work (gives the build error above):
[platformio]
lib_dir = ~/Documents/Arduino/libraries
[env:featheresp32]
board = featheresp32
;lib_deps = symlink://C:/users/nitin/Documents/Arduino/libraries/EmotiBit_SimpleFTPServer/
lib_ldf_mode = chain+; added the "+" to enable Preprocessor conditional syntax: https://docs.platformio.org/en/latest/librarymanager/ldf.html#c-c-preprocessor-conditional-syntax
File that works:
[platformio]
;lib_dir = ~/Documents/Arduino/libraries
[env:featheresp32]
;lib_ldf_mode = chain+
The issue, seems like, is coming from here: EmotiBit_SimpleFTPServer/FtpServer.h at 36818e9ea9417b04febf5738035eb7cf74ceaf76 · EmotiBit/EmotiBit_SimpleFTPServer · GitHub
Additional notes:
- The #defines are set correctly to activate that section
- If I just pull out the
#include "WiFi.h"
from inside the nested#if
and place it at the top of theFtpServer.h
file, it just works.
I’m just trying to figure out what is throwing the LDF off. The compiler is clearly reaching the correct parts of the code, just not able to find the right file. Also, WiFi.h
is a core esp file, So I’m wondering how that is being missed.
Also, as I said, this library is a smaller piece of a bigger project. I would want to get the lib_dir
approach working as that is how the current project is setup. Moving to lib_deps=symlink
could be a bigger lift and just want to double check assumptions here before making a move.
Appreciate any thoughts!
