I’m trying to build a project and this is the output.
‘platformio’ is not recognized as an internal or external command,
operable program or batch file.
Unable to execute: platformio
Make sure cmd:‘platformio’ and cwd:‘C:\Users\Project_PlatformIO\fProject’ exists and have correct access permissions.
Binaries are found in these folders: C:\Python34…
Yesterday, i can build the project correctly, but after make the PlatformIO upgrade, I can`t do anything.
I try to include the path “C:\Users.atom\packages\platformio-ide\penv\Scripts” in PATH, but with no results.
Hi @Dr.C !
Which version of python is installed in your system? I see you have Python 3.4 in your path. Currently, PlatformIO only supports Python 2.x versions. Have you tried to reinstall platformio-ide plugin?
The output from python --version is “Python 3.4.3”
Probably, it’s our problem. Could your please temporarily delete path to Python 3.4.3 from your %PATH% environment variable and try to reinstall PlatformIO IDE plugin?
I have the same issue. I also tried a complete reinstall but I still have the same error message. It does work if I open a terminal inside atom and call platformio. But the menu build and clean commands do not work.
Strange I had a reboot in the meantime and it started working. I doubt that this did anything but now also with “Path” as system variable I no longer get the errors.
I am still having this issue.
I have Windows 10 & Python 2.7.10.
I have turned off McAffee realtime scan to reload platformio
I deleted the .atom directory
platformio reinstalled without any errors
If I run the “>_” command I can use pio or platformio
If I try to compile I get "‘platformio’ is not recognized as an internal or external command, operable program or batch file."
I have tried the above mentioned maintenance.js trick, but the problem persists.
What can I do net?
Thanks for your help.
Update: If I open the “>_” command line and enter “platformio run” then it builds. So the issue seems to be happening with the toolbar shorcuts.
