I am attempting to install PlatformIO on an existing Atom installation on my MacBook Pro running OS 10.8.5 and I get the following error:
“PlatformIO is written in Python and depends on it. However, “python” command has not been found in your system PATH. Please install Python 2.7 (PYTHON 3 IS NOT SUPPORTED YET) and don’t forget to “Add python.exe to Path” on the “Customize” stage.”
Immediately after the error are three buttons: “Abort PlatformIO IDE Installation”, “Try Again” and “Install Python 2.7”
This looks like a Windows error (referencing PATH and python.exe), so I’m not sure what that is about. But I’d love some guidance!
When I open Terminal and type in python, Python 2.7.11 loads fine (python is a symlink to python2.7 in Library/Frameworks/Python.framework/Versions/2.7/bin).
I tested this, then just to make certain everything was default, I clicked the “Install Python 2.7” button and performed a new installation. Still no love.
I also have Python 3.5 installed, but it uses python3.5 symlink, pointing to Library/Frameworks/Python.framework/Versions/3.5/bin.
Again, I’m psyched to start using PlatformIO and would greatly appreciate any guidance/help/advice that anyone can offer. Please just let me know if you need any further information and I will provide it ASAP.
Thank you!
