with this config
[env:Nomad_BMS_ESP32-S3-WROOM-1-N4R2]
platform = espressif32@6.5.0 ; esp-idf v5.1.2
board = Nomad_BMS_ESP32-S3-WROOM-1-N4R2
framework = espidf
monitor_filters =
direct
esp32_exception_decoder
build_type = debug
-D NOMAD_FIRMWARE_VERSION_MAJOR=0
-D NOMAD_FIRMWARE_VERSION_MINOR=47
extra_scripts = post:make_uf2.py
my project builds fine, but I want a production env, so I do:
[platformio]
default_envs = Nomad_BMS_ESP32-S3-WROOM-1-N4R2
framework = espidf
monitor_filters =
direct
build_type = debug
[env:prod]
framework = espidf
build_type = release
but when I run pio run -e prod I get the error src/ble.c:25:10: fatal error: esp_bt.h: No such file or directory. Inspecting the .pio/build directories, it has created a different directory structure for /prod
any help?
thanks
