Platformio.ini for single project with libraries for multiple platforms
Hi everyone,
I have a project that needs to run in different MCUs (different platform and different boards) but all using the same Arduino framework. Right now, the two MCUs that I’m testing with are the Arduino Pro Mini 8Mhz and the Teensy LC. Aside from using the Arduino libraries, I also have custom libraries, some are specific to the TeensyLC and some are specific to Atmel AVR. These libraries deal mostly with interrupts and sleep functions.
How do I organize my libraries and the platformio.ini so that depending on the default_envs I choose, PlatformIO will select the correct libraries?
My platformio.ini:
[platformio]
default_envs = pro8MHzatmega328
;default_envs = teensylc
;                              ENVIRONMENTS PARAMETERS                                 ;
;Libraries and parameters shared accross environements                                 ;
[libraries]
elapsedmillis = elapsedMillis
softwareserial = SoftwareSerial
servo = Servo
[env]
  ${libraries.elapsedmillis}
  ${libraries.softwareserial}
  ${libraries.servo}
  ZigbeeProcessorXBee
monitor_filters = time, send_on_enter
monitor_flags = --echo
monitor_speed = 57600
[env:teensylc]
platform = teensy
board = teensylc
lib_extra_dirs =
  ${PROJECT_DIR}\extra\teensy
  ${env.lib_deps}
  ZP_Teensy
[env:pro8MHzatmega328]
board = pro8MHzatmega328
monitor_port = COM5
upload_port = COM5
upload_flags = -e
lib_extra_dirs =
  ${PROJECT_DIR}\extra\atmel
  ${env.lib_deps}
  ZP_Atmel
Thanks!
There is a nice example:
Manual
