Hello
this is not an important question
I fiddle with an ESP32-S3 and Bodmers eSPI
this is my Pin assignments in Setup70b_ESP32_S3_ILI9341.h and it work
// Setup for the ESP32 S3 with ILI9341 display
// Note SPI DMA with ESP32 S3 is not currently supported
#define USER_SETUP_ID 70
// See SetupX_Template.h for all options available
#define ILI9341_DRIVER
// Typical board default pins - change to match your board
#define TFT_CS 10 // 10 or 34 (FSPI CS0)
#define TFT_RST 6
#define TFT_DC 7
#define TFT_MOSI 35 // 11 or 35 (FSPI D)
#define TFT_SCLK 36 // 12 or 36 (FSPI CLK)
#define TFT_MISO 37 // 13 or 37 (FSPI Q)
// Use pins in range 0-31
//#define TOUCH_CS 16 // Optional for touch screen
#define LOAD_GLCD
#define LOAD_FONT2
#define LOAD_FONT4
#define LOAD_FONT6
#define LOAD_FONT7
#define LOAD_FONT8
#define LOAD_GFXFF
#define SMOOTH_FONT
// FSPI (or VSPI) port (SPI2) used unless following defined. HSPI port is (SPI3) on S3.
//#define USE_HSPI_PORT
//#define SPI_FREQUENCY 27000000
// #define SPI_FREQUENCY 40000000 // Maximum for ILI9341
//#define SPI_READ_FREQUENCY 6000000 // 6 MHz is the maximum SPI read speed for the ST7789V
#define SPI_TOUCH_FREQUENCY 2500000
I also have the Yellow cheap Display ESP32-2432S028
and in this example is this platformIO.ini and it works.
I altered the ini for the ESP32-S3 and I don’t get it to work
Does someone know how to change so I can run the ESP32-S3
because then I don’t have to change the files in bodmer/TFT_eSPI
[platformio]
src_dir = . ; src/main.cpp
default_envs = cyd ; ???
[env]
platform = espressif32 ;OK
board = esp32-s3-devkitc-1
bodmer/TFT_eSPI@^2.5.33
https://github.com/PaulStoffregen/XPT2046_Touchscreen.git#v1.4
upload_speed = 921600
board_build.partitions=min_spiffs.csv
-DUSER_SETUP_LOADED
-DUSE_HSPI_PORT
-DTFT_CS=10
-DTFT_RST=6
-DTFT_DC=7
-DTFT_MOSI=35
-DTFT_SCLK=36
-DTFT_BL=3
-DTFT_MISO=37
-DTFT_BACKLIGHT_ON=HIGH
-DSPI_FREQUENCY=20000000
-DSPI_READ_FREQUENCY=20000000
-DSPI_TOUCH_FREQUENCY=2500000
-DLOAD_GLCD
-DLOAD_FONT2
-DLOAD_FONT4
-DLOAD_FONT6
-DLOAD_FONT7
-DLOAD_FONT8
-DLOAD_GFXFF
[env:cyd]
${env.build_flags}
-DILI9341_2_DRIVER
[env:cyd2usb]
${env.build_flags}
-DST7789_DRIVER
-DTFT_RGB_ORDER=TFT_BGR
-DTFT_INVERSION_OFF
