I got a question about the usage of platfomio.ini build_type=test when I am trying to sift through an unit-test configuration originally for PlatformIO 4.
When I set the build_type = test on a configuration, the project configuration will return -
Error: Nothing to build. Please put your test suites to the ‘/home/williamto/project123/test’ folder and the configuration is unusable regardless of test_build_src setting.
I am not sure whether there is need for an unique configuration for unit testing, but at the same time not sure whether the PIO_UNIT_TESTING will be enforced without build_type setting.
File hierarchy for tests has changed significantly in newer PlatformIO core versions, now in test/, there should be folders starting with test_..., check out
If I move the contents in test_embedded/ into the main test/ subdirectory the “Error: nothing to build” disappears. However if I move to the same directory structure as shown in the example PlatformIO complains about nothing to build.
I finally understand why now - The PlatformIO test framework picks up the test cases under the test/ subdirectory and runs those tests according to the currently selected environment. I do not need a separate [env:test] configuration to run any of the unit tests defined under the test/ subdirectory and it is incorrect to do so.
So I deleted the extra [env:test] configuration and then run the defined unit tests with pio test command.
