Platformio.ini common settings for release and debug but not for native
I have setup a platformIO project where I use “[env]” to define common settings for release and debug. See shortened example below:
[env]
platform = https://github.com/platformio/platform-ststm32.git
board = nucleo_f091rc
framework = stm32cube
board_build.ldscript = LinkerScript.ld
[env:release]
build_flags = -Os
[env:debug]
build_type = debug
build_flags = -DDEBUG -O2 -ggdb3 -g3
Now I want to add unit testing so I added the native environment:
[env:native]
platform = native
When I try to run the unittest I get the “Unknown Board ID” error, because [env:native] also inherits the common settings from [env]. If I copy the [env] settings in [env:release] and [env:debug] and remove the [env] section it works. But then I loose the advantage of a common section for release and debug settings. What is the best way to handle this? Any good practices?
Per docs there are multiple ways.
You can put options that are shared but not shared with all environments also in a seperate environment (not called env) and reference them with the name of the environment and attribute.
[common_embedded]
linker_script = LinkerScript.ld
[env:release]
platform = ${common_embedded.platform}
board = ${common_embedded.board}
framework = ${common_embedded.framework}
board_build.ldscript = ${common_embedded.linker_script}
build_flags = -Os
[env:debug]
build_type = debug
[env:native]
platform = native
; clean, no auto-inherit
The settings are still only defined once but the inclusion has to be repeated in every environment.
A shorter way would be with the extends directive. A common embedded environment is created which is simply inherited and extended by other more concrete embedded environments.
[common_embedded]
[env:release]
extends = common_embedded
build_flags = -Os
[env:debug]
build_type = debug
[env:native]
platform = native
; extends nothing.
The “extends” directive is what I was looking for, thanks for pointing it out!
If anybody else wondered, it is possible to combine extends and interpolation:
[env:native]
platform: native
test_filter = native/*
; notice `lib_deps` is not defined
[env:native_arduino]
extends = env:native
; `platform` is inherited automatically
test_filter =
    ${env:native.test_filter}
    native_arduino/*
    ${env:native.lib_deps}
    fabiobatsilva/ArduinoFake
