Platformio in VScode hangs up whne trying to:- Switch PlatformIO Project Environment
Hello Community,
I hope I explain this correctly.
I have in my Vscode (Workspace) four projects that I’m using to develop a robust ECG monitor with various filtering options. At some point during working between the projects as I test different solutions the ‘Switch PlatformIO Project Environment’ function/operation locks up and does not switch to the selected environment. I notice this when I start to implement the PlatformIO:Upload.
I have to confess I don’t always use PlatformIO:Build first before using PlatformIO:Upload if I’m just making small software adjustment to the working code.
The only solution I’ve found is to exit VScode and restart VScode, where Platfomio reinitiates itself and starts to work again as expected where I am able to switch between Projects.
I’m not sure if this is something associated with VScode or the Platformio environment?
Kind Regards,
Degs
Four projects can complicate environment switching. Enable platformio-ide.activateProjectOnTextEditorChange in VS Code Settings. This helps activate the currently selected project’s environment. Verify the correct project and environment before uploading.
Is it possible in your current environment to run four separate instances of VS Code in parallel—one for each of your projects?
Or are you already doing this?
