Trying to switch to littlefs, Cut and pasted the “board_build.filesystem = littlefs” line to platform.ini file but it seems to be ignored. System stilll tries to create the default spiffs.bin file. Here’s the platform.ini file
[env:esp32doit-devkit-v1]
board = esp32doit-devkit-v1
debug_tool = esp-prog
fastled/FastLED@^3.4.0
ESP Async WebServer
arduino-libraries/Arduino_JSON @ 0.1.0
lorol/LittleFS_esp32@^1.0.5
upload_port = com3
and the build output for the filesystem image
> Executing task: C:\Users\royan\.platformio\penv\Scripts\platformio.exe run --target buildfs --environment esp32doit-devkit-v1 <
Processing esp32doit-devkit-v1 (platform: espressif32; board: esp32doit-devkit-v1; framework: arduino)
PLATFORM: Espressif 32 (3.2.0) > DOIT ESP32 DEVKIT V1
- framework-arduinoespressif32 3.10006.210326 (1.0.6)
- tool-esptoolpy 1.30000.201119 (3.0.0)
- toolchain-xtensa32 2.50200.97 (5.2.0)
Found 33 compatible libraries
|-- <FastLED> 3.4.0
| |-- <SPI> 1.0
|-- <ESP Async WebServer> 1.2.3
| |-- <AsyncTCP> 1.1.1
| |-- <FS> 1.0
| |-- <WiFi> 1.0
|-- <Arduino_JSON> 0.1.0
|-- <LittleFS_esp32> 1.0.5
| |-- <FS> 1.0
|-- <WiFi> 1.0
|-- <FS> 1.0
Building SPIFFS image from 'data' directory to .pio\build\esp32doit-devkit-v1\spiffs.bin
/Becky1.bmp
/Becky2.bmp
/Betty1.bmp
As noted above it’s building spiffs.bin, in fact has a later error because it doesn’t like the included subfolder.
Puzzled as no one else seems to have the issue? This is on a new clean Windows install in the last month so should be uptodate.
