PlatformIO ignores #ifdef Includes
Hallo together,
i have following problem.
After a Update for Platformio the #include “file” in preprocessor #ifdef get ignored.
#ifndef DeviceDefinition_H
#define DeviceDefinition_H
#include "Arduino.h"
#define USE_MCP23017
#ifdef USE_MCP23017
    #include "MCP23017.h"
    MCP_23017Class Device;
#ifdef USE_Gateway
    #include "Gateway.h"
    GatewayClass Device;
#ifdef USE_PCA9685
    #include "PCA9685.h"
    PCA9685Class Device;
Befor the update all works fine. But now it throw a “no such file” error message. If i define the Class
outside the #ifdef it works again.
I tryed to clean the project, deleted the .pio folder, changed lib_ldf_mode from chain+ to deep+.
But nothing helped.
Does anyone have the same troubles?
Thanks for help :slight_smile:
Can you post the exact error? Is it a compiler error or a VSCode intellisense error? If it’s a compiler error, what’s the full log?
PLATFORM: Espressif 32 1.12.0 > Espressif ESP32 Dev Module
DEBUG: Current (esp-prog) External (esp-prog, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd,
olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa)
LDF Modes: Finder ~ chain+, Compatibility ~ soft
Found 35 compatible libraries
|-- <ArduinoJson> 6.11.0
|-- <Dictionary>
|-- <SPIFFS> 1.0
|   |-- <FS> 1.0
|-- <FS> 1.0
|-- <GlobalFunction>
|   |-- <Dictionary>
|   |-- <FS> 1.0
|   |-- <SPIFFS> 1.0
|   |   |-- <FS> 1.0
Compiling .pio\build\esp32dev\src\main.cpp.o
Generating partitions .pio\build\esp32dev\partitions.bin
Archiving .pio\build\esp32dev\lib74c\libArduinoJson_ID64.a
Compiling .pio\build\esp32dev\libc99\Dictionary\Dictionary.cpp.o
Compiling .pio\build\esp32dev\lib594\FS\FS.cpp.o
Compiling .pio\build\esp32dev\lib594\FS\vfs_api.cpp.o
Compiling .pio\build\esp32dev\lib4d4\SPIFFS\SPIFFS.cpp.o
Compiling .pio\build\esp32dev\libbb3\GlobalFunction\GlobalFunction.cpp.o
lib\Dictionary\src\Dictionary.cpp: In member function 'Objects_t*
DictionaryClass::Object_Search(uint16_t)':
lib\Dictionary\src\Dictionary.cpp:255:1: warning: control reaches end of non-void function [-Wreturn-
type]
Archiving .pio\build\esp32dev\libFrameworkArduinoVariant.a
In file included from lib\GlobalFunction\src\GlobalFunction.cpp:2:0:
lib\GlobalFunction\src\DeviceDefinition.h:9:30: fatal error: MCP23017.h: No such file or directory
 * Looking for MCP23017.h dependency? Check our library registry!
* CLI  > platformio lib search "header:MCP23017.h"
* Web  > https://platformio.org/lib/search?query=header:MCP23017.h
compilation terminated.
 *** [.pio\build\esp32dev\libbb3\GlobalFunction\GlobalFunction.cpp.o] Error 1
 Compiling .pio\build\esp32dev\FrameworkArduino\Esp.cpp.o
Thats the Error i get .
I don’t even find a reference for a library which implements MCP_23017Class. Which library do you use? Does declaring it in lib_deps help?
If not, can you share a minimal project which reproduces the problem?
Puh thats a little bit tricky.
main.cpp
 #include "GlobalFunction.h"
 InitDevice();
 void loop()
GlobalFunction.h
#ifndef GlobalFunction_H
#define GlobalFunction_H
 void InitDevice();
GlobalFunction.cpp
#include "DeviceDefinition.h"
void InitDevice(){
   if(!Device.Init_Task()){
DeviceDefinition.h
   #ifdef USE_MCP23017
Soo i try to explain.
There are several ESP32 and they got different Perepherie one for example the MCP23017.
In the DeviceDefinition.h i choose which perepherie the compilier have to use.
I want to have a changeble Instance of “Device.” and this worked until the newest update.
Now: if i put the #include “MCP23017.h” in “DeviceDefinition.h” befor the “#ifdef Use_MCP23017” it works all fine.
platformio.ini
build_unflags = -std=gnu++11
build_flags = -std=gnu++17
build_unflags = -fno-rtti
upload_port = COM11
upload_resetmethod = nodemcu
monitor_port = COM11
monitor_speed =115200
;monitor_rts = 0
;monitor_dtr = 0
  ArduinoJson@6.11.0
 lib_ldf_mode = chain+
Please remove a space before lib_ldf_mode
Thanks for reply but the space only happend because of copy and paste and than format the code in the reply message editor.
Strange is the following.
I bind in the “Device” library in the DeviceDefinition.h. (wich is part of the GlobalFunction Folder)
If i choose the Gateway.h wich is befor the GlobalFunction folder than it works, but if i choose the MCP23017.h or PCA9685 than is get the error.
Unbenannt
Thanks and a nice weekend.
