Last monday, PlatformIO could not load a Home tab with no apparent reason.
Environment:
Win7
VSCode 1.70.3
Python 3.8.9
After several checks that showed nothing (seemingly) wrong, I’ve done a lot of measures, some more than once, all ineffective:
remove PlatformIO and reinstall it
remove VSCode and reinstall it
remove Python v3.8.9 and reinstall it.
Remove remaining folders like “.platformio”, “.vscode” after uninstalling related software
Looking for such a problem I’ve found several cases since 2018, but solutions presented have been worthless.
Below, some screenshots that may be useful.
Any clue?
"Error: Traceback (most recent call last):
File “C:.platformio.cache\tmp.piocore-installer-bdgxnu4j\tmpvt8gwb69\pioinstaller.zip\pioinstaller\core.py”, line 169, in check
File “C:\Users\Admin\AppData\Local\Programs\Python\Python38\lib\subprocess.py”, line 415, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “C:\Users\Admin\AppData\Local\Programs\Python\Python38\lib\subprocess.py”, line 516, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command ‘[‘C:\.platformio\penv\Scripts\platformio.exe’, ‘–help’]’ returned non-zero exit status 1.
During handling of the above exception, another excep…"
Why is trying to do it in C:\.platformio? It should pick <user directory>\.platformio here. Did you run VSCode as admin? Did you try running it without?
Otherwise I would suggest
Deactivate the CMake Tools extension
Remove C:\Users\<user>\.platformio (or C:\.platformio if it exists)
Restart VSCode, let the extension reinstall it’s core.
File “C:\Users\Admin.platformio.cache\tmp.piocore-installer-7jwavxns\tmpz0jyoy8x\pioinstaller.zip\pioinstaller\core.py”, line 169, in check
subprocess.CalledProcessError: Command ‘[‘C:\Users\Admin\.platformio\penv\Scripts\platformio.exe’, ‘–help’]’ returned non-zero exit status 1.
Yes, there’s platformio.exe in that folder and when it is run (C:\Users\Admin.platformio\penv\Scripts>platformio.exe --help), that results:
File "C:\Users\Admin\.platformio\penv\lib\site-packages\platformio\__main__.py", line 102, in main
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1130, in __call__
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1054, in main
with self.make_context(prog_name, args, **extra) as ctx:
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 920, in make_context
self.parse_args(ctx, args)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1613, in parse_args
rest = super().parse_args(ctx, args)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1378, in parse_args
value, args = param.handle_parse_result(ctx, opts, args)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 2360, in handle_parse_result
value = self.process_value(ctx, value)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 2322, in process_value
value = self.callback(ctx, self, value)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1273, in show_help
echo(ctx.get_help(), color=ctx.color)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 699, in get_help
return self.command.get_help(self)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1298, in get_help
self.format_help(ctx, formatter)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1331, in format_help
self.format_options(ctx, formatter)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1533, in format_options
self.format_commands(ctx, formatter)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\click\core.py", line 1586, in format_commands
cmd = self.get_command(ctx, subcommand)
File "C:\Users\Admin\.platformio\penv\lib\site-packages\platformio\cli.py", line 80, in get_command
module = importlib.import_module(commands[cmd_name])
File "C:\Users\Admin\AppData\Local\Programs\Python\Python38\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\Admin\.platformio\penv\lib\site-packages\platformio\commands\ci.py", line 24, in <module>
from platformio.project.commands.init import project_init_cmd, validate_boards
File "C:\Users\Admin\.platformio\penv\lib\site-packages\platformio\project\commands\init.py", line 55, in <module>
@click.option("--ide", type=click.Choice(ProjectGenerator.get_supported_ides()))
File "C:\Users\Admin\.platformio\penv\lib\site-packages\platformio\project\integration\generator.py", line 62, in get_supported_ides
for name in os.listdir(tpls_dir)
FileNotFoundError: [WinError 3] O sistema não pode encontrar o caminho especificado: 'C:\\Users\\Admin\\.platformio\\penv\\lib\\site-packages\\platformio\\assets\\templates\\ide-projects'
`pip install -U platformio` command
After running “pip install -U platformio”:
Microsoft Windows [versão 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. Todos os direitos reservados.
C:\Users\Admin>cd
C:\Users\Admin
C:\Users\Admin>cd C:\Users\Admin\.platformio\penv\Scripts
C:\Users\Admin\.platformio\penv\Scripts>platformio.exe --help
After running "C:\Users\Admin\.platformio\penv\Scripts>pip install -U platformio":
"Requirement already satisfied: platformio in c:\users\admin\.platformio\penv\lib\site-packages (6.1.6a3)
Requirement already satisfied: pyelftools<1,>=0.27 in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.29)
Requirement already satisfied: starlette==0.22.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.22.0)
Requirement already satisfied: marshmallow==3.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (3.19.0)
Requirement already satisfied: aiofiles==22.1.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (22.1.0)
Requirement already satisfied: pyserial==3.5.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (3.5)
Requirement already satisfied: uvicorn==0.20.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.20.0)
Requirement already satisfied: click<9,>=8.0.4 in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (8.1.3)
Requirement already satisfied: colorama in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.4.6)
Requirement already satisfied: requests==2.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (2.28.1)
Requirement already satisfied: semantic-version==2.10.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (2.10.0)
Requirement already satisfied: bottle==0.12.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.12.23)
Requirement already satisfied: wsproto==1.2.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (1.2.0)
Requirement already satisfied: tabulate==0.9.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.9.0)
Requirement already satisfied: ajsonrpc==1.* in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (1.2.0)
Requirement already satisfied: zeroconf<1 in c:\users\admin\.platformio\penv\lib\site-packages (from platformio) (0.39.4)
Requirement already satisfied: packaging>=17.0 in c:\users\admin\.platformio\penv\lib\site-packages (from marshmallow==3.*->platformio) (21.3)
Requirement already satisfied: idna<4,>=2.5 in c:\users\admin\.platformio\penv\lib\site-packages (from requests==2.*->platformio) (3.4)
Requirement already satisfied: charset-normalizer<3,>=2 in c:\users\admin\.platformio\penv\lib\site-packages (from requests==2.*->platformio) (2.1.1)
Requirement already satisfied: urllib3<1.27,>=1.21.1 in c:\users\admin\.platformio\penv\lib\site-packages (from requests==2.*->platformio) (1.26.12)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\admin\.platformio\penv\lib\site-packages (from requests==2.*->platformio) (2022.9.24)
Requirement already satisfied: typing-extensions>=3.10.0 in c:\users\admin\.platformio\penv\lib\site-packages (from starlette==0.22.*->platformio) (4.4.0)
Requirement already satisfied: anyio<5,>=3.4.0 in c:\users\admin\.platformio\penv\lib\site-packages (from starlette==0.22.*->platformio) (3.6.2)
Requirement already satisfied: h11>=0.8 in c:\users\admin\.platformio\penv\lib\site-packages (from uvicorn==0.20.*->platformio) (0.14.0)
Requirement already satisfied: async-timeout>=4.0.1 in c:\users\admin\.platformio\penv\lib\site-packages (from zeroconf<1->platformio) (4.0.2)
Requirement already satisfied: ifaddr>=0.1.7 in c:\users\admin\.platformio\penv\lib\site-packages (from zeroconf<1->platformio) (0.2.0)
Requirement already satisfied: sniffio>=1.1 in c:\users\admin\.platformio\penv\lib\site-packages (from anyio<5,>=3.4.0->starlette==0.22.*->platformio) (1.3.0)
Requirement already satisfied: pyparsing!=3.0.5,>=2.0.2 in c:\users\admin\.platformio\penv\lib\site-packages (from packaging>=17.0->marshmallow==3.*->platformio) (3.0.9)"
Finally, I have PlatformIO working again.
I could not say if some of the things I did thru all these days contributed or not. A lot of tries, indeed.
Right now, I’ve Python 3.8.7 installed, as a replacement of the previous 3.8.9 version, one of the tries in a chase in the dark to (try to) solve the problem.
Was this problem caused by something present in my PC and/or was that due some PlatformIO issue present in a recent update?
