Import Arduino IDE Project in Atom
2.1 That adds the selected folder to a subfolder and creates additional Atom-specific folders
Now the whole github project is out of sync with the upstream project
3.1 How can I keep syncing with the upstream project? (like here: Syncing a fork - GitHub Docs)
Submodules? Pointers (if there is such a thing)? Anything?
Maybe the question should go out to the github community…I have limited knowledge of git, so please forgive me my ignorance…
1-4 OK, thats what I already tried
5: No such option when opening project. Furthermore, cannot build project:
Can not find PlatformIO project.
Make sure that project you’re trying to buid is a PlatformIO project (e. g., contains platformio.ini).
If I “Import Arduino Project” and check “Keep compatible between Arduino IDE” (guess that is what you meant anyway…), the content of the selected folder is copied to a subfolder with the same name as the parent - along with additional folders. Then the whole thing is messed up in terms of keeping it in SYNC with the upstream project. So your suggestion does not work…
