PlatformIO failes to start debugger on ARM
Configuration
Operating system: Linux ubuntu-arm 5.15.0-56-generic #62-Ubuntu SMP Tue Nov 22 19:56:13 UTC 2022 aarch64 aarch64 aarch64 GNU/Linux
PlatformIO Version: latest
Description of problem
I am currently running a ubuntu virtual machine on my M1 because debugging also fails under MacOS. (Missing python 2.7 installation on MacOS Monterey 12.6 when trying to start debug session · Issue #292 · platformio/platform-atmelavr · GitHub)
Steps to Reproduce
  1. Create an ubuntu-server ARM virtual machine
  2. Install build-essential and gdb
  3. Start debugging (in my case an Attiny with usbASP)
Actual Results
VSCode prompts the following error under debug console:
undefinedPython Exception <type 'exceptions.ImportError'> No module named gdb:
warning:
Could not load the Python gdb module from '/home/nvidia/jenkins/workspace/avr-gcc-staging/label/nvidia-jetson-aarch64/objdir/share/gdb/python'.
Limited Python support is available from the _gdb module.
Suggest passing --data-directory=/path/to/gdb/data-directory.
Expected Results
I can start debugging.
Can you append this info in the open bug report here please
I was able to start the debugger with self built gcc, gdb and binutils under my ARM VM in UTM.
Only to find out that the attiny is unsupported to be debugged with usbasp.
By accident I have started simavr, but which will also not work, because of a missing flash erasure function.
AVR debug probes and open-source GDB servers are poorly supported in my opinion. Microchip’s Atmel Studio is the only stable proprietary solution, see Custom AVR XMEGA board - #11 by maxgerhardt.
Is it a ATTiny x5? Maybe PR Enable self-programming for attinyx5 by orukusaki · Pull Request #513 · buserror/simavr · GitHub would help. If not, please open an issue at simavr to get that program improved.
Unfortunately it is an attiny2313. I thought I can just use the MOSI, MISO, SCK pins because the PIO documentation said that JTAG is enabled on this chip and no external debugger needed.
The only options now I have are simavr and custom, where simavr is definitely not what I want. (and yes, I can document the bug and create a ticket when I have time the next days)
Do you know any serial debugger / stub debugger which would fit into the 2K flash of the Attiny?
Even then I would not be able to debug my own UART because the single hardware UART would then be taken by the serial debugger.
When the documentation had been more clearly, I would not have wasted money into hardware which is currently very unsupported.
