Hello, recently I cannot use the PlatformIO extension anymore. I’ve been using it for about 4 months but yesterday it randomly stopped working. I opened VSCode to work on a project but the extension icon didn’t appear on the left bar (also the upload, test etc icons on the bottom bar weren’t there). So I tried:
Uninstalling the extension, reloading, installing the extension;
uninstalling the extension and VSCode and reinstalling everything;
uninstalling the extension and VSCode, deleting every folder and file related to them, and reinstalling everything.
I’m using PlatformIO on Windows 10 with VSCode version 1.73.1. Today (21.11.2022) I got an issue during an automatic update of the PlatformIO Core. To solve the issue I tried a new installation as follows:
Uninstall PlatformIO from VSCode Extenssions
Stop VScode
Remove the directory “C:\Users\xxxxxxxx.platformio”
Start VSCode
Install PlatformIO IDE v2.5.5 Extenssion
The installation terminated with the following error:
Error: Error: Compatible PlatformIO Core not found.
Reason: Could not run C:\Users\xxxxxxxx\.platformio\penv\Scripts\platformio.exe --help.
Error: Error: Traceback (most recent call last):
File “C:\Users\xxxxxxxx.platformio\penv\lib\site-packages\platformio_main_.py”, line 102, in main
File “C:\Users\xxxxxxxx.platformio\penv\lib\site-packages\click\core.py”, line 1130, in call
File “C:\Users\xxxxxxxx.platformio\penv\lib\site-packages\click\core.py”, line 1054, in main
with self.make_context(prog_name, args, **extra) as ctx:
File "C:\Users\xxxxxxxx.platformio\penv\lib…
What are your VSCode settings? Did you disable the built-in PlatformIO Core? Please check VSCode settings and RESTORE to the default state all PlatformIO IDE settings.
I don’t have any special settings in VSCode. It is a default installation.
At 18:30 CET I started my VSCode again and the PlatformIO extenssion was busy about 3 minutes with “PlatformIO: Loading tasks…”. Now everything seems to work like yesterday.
PlatformIO was installing project dependencies that used an Internet connection. The upcoming PlatformIO IDE 3.0 for VSCode improves UX and shows more details.
the last 3 days it was possible to work with PlatformIO without any issues.
Today at about 19:15 CET I got the same issue as 4 days ago. Wenn I start the the VSCode, the following activities will be show in the bottom right corner:
Could you navigate to the Extensions tab (left activity bar), click on PlatformIO IDE extension, and switch to the pre-release version? Do you still experience this issue?
