Platformio.exe hangs
If I run any command in my project: clean, build, upload, even serial terminal… Then the platformio.exe hangs in visual code terminal. I can see the command line launches the executable but it does nothing after.
Originally, VS Code wouldn’t launch I’d click the icon to load VS Code and nothing would happen. I reinstalled VS Code and this issue with platformio surfaced.
So far I:
  • Uninstalled VS Code, Python, Git, and deleted the platformio folder under users
  • I rebooted twice afterward each reinstall
  • Reinstalled VS Code and the Platformio executable.
  • Tried rolling back to previous version of platformio
  • Firewall is disabled
  • Virus checker is disabled
  • I tried loading software as administrator
  • All my path variables are there for Git and Python
I’ve tried above in any number of combinations for several hours now…
  • I also tried deleting the platformio build folders in the project.
Everything is same result. I’m running Windows 10. Monitoring task manager during any invocation of the Platoformio.exe I notice the CPU never idles back down for the task. Platformio.exe just hangs and does nothing. I’m running out of ideas to try and get this running.
I solved it. Discovered terminal in VS Code was frozen / non-responsive. It was due to “Compatibility mode” having gotten checked somehow. Now platformIO works as expected.
