ehouet
September 13, 2025, 6:55pm
1
I have the ESP32-C3-01M board (description here ).
When I program this board in the Arduino IDE, with this program:
#define RGBLED_RED 3
#define RGBLED_GREEN 4
#define RGBLED_BLUE 5
#define RED_PATTERN 0b11111110
#define GREEN_PATTERN 0b00001111
#define BLUE_PATTERN 0b11001100
uint8_t nCounter = 0;
uint8_t nChecker = 1;
pinMode(RGBLED_RED, OUTPUT);
pinMode(RGBLED_GREEN, OUTPUT);
pinMode(RGBLED_BLUE, OUTPUT);
digitalWrite(RGBLED_RED, ((RED_PATTERN & nChecker) != 0) ? HIGH : LOW);
digitalWrite(RGBLED_GREEN, ((GREEN_PATTERN & nChecker) != 0) ? HIGH : LOW);
digitalWrite(RGBLED_BLUE, ((BLUE_PATTERN & nChecker) != 0) ? HIGH : LOW);
delay(125);
nCounter++;
nCounter = nCounter % 8;
nChecker = 1 << nCounter;
all three LEDs do their pattern like described in their pattern.
But if I make a program almost the same as above in Visual Studio Code with the platformio extension with the Espressif32:
#include <stdio.h>
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include "driver/gpio.h"
void app_main()
gpio_set_direction(RGBLED_GREEN, GPIO_MODE_OUTPUT);
gpio_set_direction(RGBLED_RED, GPIO_MODE_OUTPUT);
gpio_set_direction(RGBLED_BLUE, GPIO_MODE_OUTPUT);
while (true)
gpio_set_level(RGBLED_GREEN, ((GREEN_PATTERN & nChecker) != 0) ? 1 : 0);
gpio_set_level(RGBLED_RED, ((RED_PATTERN & nChecker) != 0) ? 1 : 0);
gpio_set_level(RGBLED_BLUE, ((BLUE_PATTERN & nChecker) != 0) ? 1 : 0);
//vTaskDelay(500 / portTICK_PERIOD_MS);
//gpio_set_level(RGBLED_BLUE, 0);
vTaskDelay(125 / portTICK_PERIOD_MS);
nCounter++;
Then only the red LED is doing its pattern. I cannot switch on the green or blue LED.
Even though I make a program with only turning on the green or blue LED.
What do I need to do to fix this, because I rather like the platformio extension.
With kind regards,
Erik
GPIO4 and 5 are JTAG pins by default (MTMS and MTDI). Calling gpio_set_direction() does not seem to be enough to relieve them of their JTAG functionality. Try this instead.
#include <stdio.h>
void app_main()
gpio_reset_pin(RGBLED_GREEN); // JTAG MTMS
gpio_reset_pin(RGBLED_BLUE); // JTAG MTDI
while (true)
nCounter++;
You may find it clearer to use a complete gpio_config() instead of just gpio_set_direction, this should also work.
https://randomnerdtutorials.com/esp-idf-esp32-gpio-outputs/
ehouet
September 13, 2025, 7:39pm
4
This did the trick. Thanks for the extremely fast answer.
Greetings,
Erik
ehouet
September 13, 2025, 7:40pm
5
I tried this config before, but that doesn’t work.
Maybe I should add a reset in the config as well ?!?!
Does this not work?
#include <stdio.h>
void app_main()
gpio_config_t io_conf = {
.pin_bit_mask = (1ULL << RGBLED_RED ) | (1ULL << RGBLED_GREEN) | (1ULL << RGBLED_BLUE), // Select all LED pins
.mode = GPIO_MODE_OUTPUT, // Set as output
.pull_up_en = GPIO_PULLUP_DISABLE, // Disable pull-up
.pull_down_en = GPIO_PULLDOWN_DISABLE, // Disable pull-down
.intr_type = GPIO_INTR_DISABLE // Disable interrupts
gpio_config(&io_conf);
while (true)
nCounter++;
ehouet
September 13, 2025, 7:50pm
7
Nope. This was the first thing I tried to solve the problem.
How interesting. gpio_config should do a lot of the same things that gpio_reset and gpio_set_direction does when I look at https://github.com/espressif/esp-idf/blob/89cb1d10d621266677ff1785f270e760ddd014a6/components/esp_driver_gpio/src/gpio.c#L338-L450 . Not sure about this one.
