This is the error.
*** [.pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_gpio_ex.c.o] Error 3221225477
El proceso del terminal "C:\Users\Joseph\.platformio\penv\Scripts\platformio.exe 'run'" finalizó con el código de salida 3221225477.
Las tareas reutilizarán el terminal, presione cualquier tecla para cerrarlo.
> Executing task: C:\Users\Joseph\.platformio\penv\Scripts\platformio.exe run <
Warning! `src_filter` configuration option in section [env:include_tree] is deprecated and will be removed in the next release! Please use `build_src_filter`
instead
Warning! `src_filter` configuration option in section [env:DUE] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:esp32] is deprecated and will be removed in the next release! Please use `build_src_filter` insteadWarning! `src_build_flags` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_flags` instead
Warning! `src_filter` configuration option in section [env:linux_native] is deprecated and will be removed in the next release! Please use `build_src_filter`
instead
Warning! `src_build_flags` configuration option in section [env:simulator_windows] is deprecated and will be removed in the next release! Please use `build_src_flags` instead
Warning! `src_filter` configuration option in section [env:SAMD51_grandcentral_m4] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:malyan_M300] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:STM32F103CB_malyan] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy31] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy35] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy36] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Warning! `src_filter` configuration option in section [env:teensy41] is deprecated and will be removed in the next release! Please use `build_src_filter` instead
Processing BIGTREE_SKR_2_F429 (board: marlin_STM32F429VGT6; platform: ststm32@~12.1; framework: arduino)
--------------------------------------------------------------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/ststm32/marlin_STM32F429VGT6.html
PLATFORM: ST STM32 (12.1.1) > STM32F429VG (128k RAM, 64k CCM RAM, 1024k Flash)
HARDWARE: STM32F429VGT6 168MHz, 128KB RAM, 1MB Flash
DEBUG: Current (stlink) On-board (stlink) External (jlink)
- framework-arduinoststm32 @ 0.0.0
- framework-cmsis @ 2.50501.200527 (5.5.1)
- toolchain-gccarmnoneeabi @ 1.90201.191206 (9.2.1)
Converting Marlin.ino
Found 12 compatible libraries
|-- TMCStepper @ 0.7.3
| |-- SoftwareSerial @ 1.0
| |-- SPI @ 1.0
|-- U8glib-HAL @ 0.5.2
| |-- Wire @ 1.0
| |-- SPI @ 1.0
|-- SPI @ 1.0
|-- Servo @ 1.1.2
|-- EEPROM @ 2.0.1
|-- IWatchdog @ 1.0.0
|-- Wire @ 1.0
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_cryp.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dac.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dac_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dcmi_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dfsdm_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dma.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dma2d.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dma_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dsi.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_dts.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_eth.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_eth_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_exti.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_fdcan.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_firewall.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_flash.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_flash_ramfunc.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_fmac.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_fmpi2c_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_fmpsmbus.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_gfxmmu.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_gpio.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_gpio_ex.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_hash.c.o
Compiling .pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_hash_ex.c.o
*** [.pio\build\BIGTREE_SKR_2_F429\SrcWrapper\src\HAL\stm32yyxx_hal_gpio_ex.c.o] Error *3221225477*
================================================================ [FAILED] Took 24.95 seconds ================================================================
Environment Status Duration
BIGTREE_SKR_2_F429 FAILED 00:00:24.946
=========================================================== 1 failed, 0 succeeded in 00:00:24.946 ===========================================================
El proceso del terminal "C:\Users\Joseph\.platformio\penv\Scripts\platformio.exe 'run'" finalizó con el código de salida 1
I already reistale platformio and vs code and nothing, could someone help me please
