PlatformIO doesn't respect the platform setting in my environments
I have three separate environments in my platformio.ini:
[env: doit-devkitesp32doit-devkit-v1]
[env:esp32doit-devkit-v1-i2s]
platform = espressif32@5.3.0
[env:esp32-s3-devkitc-1]
board = esp32-s3-devkitc-1
I issue the commands:
rm -rf .pio
pio platform uninstall espressif32
pio platform install espressif32@5.3.0
pio run
when the system builds the environments, it doesn’t respect the platforms and does the following:
PLATFORM: Espressif 32 (5.3.0) > Espressif ESP32 Dev Module
HARDWARE: ESP32 240MHz, 320KB RAM, 8MB Flash
PLATFORM: Espressif 32 (6.5.0) > Espressif ESP32 Dev Module
CONFIGURATION: https://docs.platformio.org/page/boards/espressif32/esp32-s3-devkitc-1.html
PLATFORM: Espressif 32 (6.5.0) > Espressif ESP32-S3-DevKitC-1-N8 (8 MB QD, No PSRAM)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
That is it respects my initial installation of espressif32@5.3.0 for the first environment but then it installs the 6.5.0 although I stated 5.3.0.
After that the builds are unsuccesful because there are library incompatibilities.
Always specify the version which should be used! If no version is specified, the one installed with the highest number will be used.
Afaik all 3 environments should be using 5.3.0?
“Nail” the version in each environment:
You can put common settings in the [env] section. You should end up with
[env]
